What do i put in the attribute section for new graphic
835
08-04-2012 03:15 PM
David_KurtTracy
I am new and piecing together samples to get this to work.  What do i put in the attribute section for new graphic.  Here is the function in question.  Let me know if you need the entire script.
function onGeocodesuccess(results)
console.log(results);
//alert(results.score.toString);
   var geoPoint = new esri.geometry.Point(results.utm_x, results.utm_y, map.spatialReference);
         var symbol = new esri.symbol.SimpleMarkerSymbol(esri.symbol.SimpleMarkerSymbol.STYLE_CIRCLE, 15, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([0,0,255]), 2), new dojo.Color([0,0,255]));
   var infoTemplate = new esri.InfoTemplate("Attributes", "${*}");
            var graphic = new esri.Graphic(geoPoint, symbol, attr, infoTemplate);
            map.graphics.add(graphic);
            map.infoWindow.setTitle(graphic.getTitle());
            map.infoWindow.setContent(graphic.getContent());
            var screenPnt = map.toScreen(geoPoint);
            map.infoWindow.show(screenPnt,map.getInfoWindowAnchor(screenPnt));
Thanks so much for your time and help.
StephenLead
Honored Contributor
It doesn't look as though you've actually set attr (the list of attributes) so this will probably fail.
See the graphic help entry for an example of how to specify the attributes:
var attr = {"Xcoord":evt.mapPoint.x,"Ycoord":evt.mapPoint.y,"Plant":"Mesa Mint"};
You can also use "*" if you wish to use all attributes.
Cheers,
Steve
