Bookmark Zoom-To with Scale Change addition
1207
07-26-2012 11:18 AM
JoshJones1
I am EXTREMELY new to the JavaScript API, and I was curious if there was a way to include a scale change with the "Bookmark Widget - Read Only" found here http://help.arcgis.com/en/webapi/javascript/arcgis/demos/widget/widget_bookmarks_dropdownbutton.html .
I have the bookmark widget working fine, but I'm nor sure how to have the scale change as well as zooming to the selected bookmark.  At this point I have used centroids of buildings as the coordinates, so I would assume that this would zoom the the lowest LOD, which is what I want, but this is not what happens.
Does anybody have any ideas or suggestions?
Thanks.
-Josh
JoshJones1
Figured it out.  I just changed it to four points, instead of two repeating x's and two repeating y's.  I believe that it required a bounding box (even if the bounding box is extremely small), not simply one point repeated twice for each x and y location.
-Josh
JoshJones1
-Josh
