WFS CORS cross proxy (Control-Allow-Origin)
8170
08-11-2015 12:16 AM
MohammedKabeer1
Dear All,
i am trying to call WFS service in arcgis javascript and its giving me following error
XMLHttpRequest cannot load http://192.168.100.47:7001/SpatialWS-SpatialWS-context-root/xmlwfsservlet?&service=WFS&request=GetCa.... No 'Access-Control-Allow-Origin' header is present on the requested resource. Origin 'http://localhost:8083' is therefore not allowed access.
here is my javascript
$(document).delegate('#wfsksaregions', 'change', function () {
         if (this.checked) {
           var opts = {
                          "url": "http://192.168.100.47:7001/SpatialWS-SpatialWS-context-root/xmlwfsservlet?",
                          "version": "1.0.0",
                          "nsLayerName": "mvdemons:wfsKsaRegions",
                          "wkid": 8307,
                          "mode": "SNAPSHOT",
                          "maxFeatures": 100,
                          "showDetails": true,
                          "infoTemplate": new InfoTemplate()
                     _public._kabopt = opts;
                    //  esriConfig.defaults.io.proxyUrl = "localhost:8083";
                     esriConfig.defaults.io.alwaysUseProxy = false;
                     esri.config.defaults.io.corsEnabledServers.push("192.168.100.47:7001","192.168.100.47:8083");
                      var wfslayer = new WFSLayer(opts);
                      _public._kabwfslayer=wfslayer;
          alert ("hellooooooooo i am here adding WFS layer111");
          _public._kablayer = wfslayer;
            map.addLayer(wfslayer);
          //_public._kabwaterbodies.show()
         else{
          alert ("hellooooooooo i am here removing WFS layer111");
          //_public._kabwaterbodies.hide()
please somebody reply me as soon as possible
Thanks
Kabeer
KristianEkenes
Is the following line pointing to your proxy file in some way?
What type of proxy are you using (PHP, JSP, DotNet)?
MohammedKabeer1
Thank u very much
I am using eclipse IDE
Yes if I keep this code esri.config.defaults.io.proxyUrl = ""; then its giving following error
esri.config.defaults.io.proxyUrl is not set. If making a request to a CORS enabled server, please push the domain into esri.config.defaults.io.corsEnabledServers.
WFSLayer.js:20 WFSLayer: Error: esri.config.defaults.io.proxyUrl is not set. If making a request to a CORS enabled server, please push the domain into esri.config.defaults.io.corsEnabledServers.
What I should I do to get rid of this error
Thanks
Kabeer
ermiastesfamariam
New Contributor II
Most browsers does not support localhost for CORS requests due to same-origin policy. In order to get CORS to work in your browser for development purpose, you can set the Access-Control-Allow-Origin,Access-Control-Allow-Headers, and Access-Control-Allow-Methods values to * in your web server.
You can aslo use a domain like lvh.me (which basically points to localhost) to fool your browser as if you are requesting from a remote server.
