WebTileLayer can not show the map data in EPSG:3826 format
1176
12-28-2023 07:41 PM
AbramhumHsu
Dear:
I meet a problem when using WebTileLayer show the map data in EPSG:3826 format.
The code snippet is as following:
  const basemap = new Basemap({
                    baseLayers: [
                        new WebTileLayer({
                            urlTemplate: "https://wmts.nlsc.gov.tw/97/wmts/EMAP3826/default/default028mm/{level}/{row}/{col}",
                            title: "Basemap",
                            crossOrigin: 'anonymous',
                            extent: {
                                xmin: 128548.4443375419,
                                ymin: 2394066.4166165744,
                                xmax: 606875.5521,
                                ymax: 2919551.2968000006,
                                spatialReference: { wkid: 102443 }
                    title: "basemap",
and the error message shows:
WebTileLayer .... spatialReference must match tileInfo.spatialReference
 Is there any other methods can cover this problem? thanks a lot.
UndralBatsukh
WebTileLayer's spatialReference is 102100. Looks like you are working with WMTS service (https://wmts.nlsc.gov.tw/97/wmts/). So I would add the layer as WMTSLayer as shown below.
const layer = new WMTSLayer({
  url: "https://wmts.nlsc.gov.tw/97/wmts"
  extent: {
    xmax: 606875.5521,
    spatialReference: { wkid: 3826 }
const map = new Map({
  layers: [layer]
const view = new MapView({
  container: "viewDiv",
  map: map,
  spatialReference: { wkid: 3826 },
UndralBatsukh
  extent: {
    xmax: 606875.5521,
  layers: [layer]
  map: map,
