Web Application Editing window size
3066
02-02-2016 06:35 AM
KelseyNovacek1
I am exploring the functionally of this editing code I was directed to which allows for a start/stop editing function that allows both editing and use of the information window when selecting features, http://jsfiddle.net/kr5kC/18/.  I am wondering what is controlling the height of the editing window when you click 'Start Editing'.  I would like to increase the height to fully utilize the screen space.  I can alter the ContentPane's width but can not pinpoint the controls of the editing window itself.
-Thank  you.
KellyHutchins
Esri Notable Contributor
I updated the fiddle to show one approach:
Edit fiddle - JSFiddle
Basically I added css to set the size for the templatePicker.
KellyHutchins
KenBuja
MVP Esteemed Contributor
One thing I noticed with both samples is that the toolbar gets moved from the bottom on the left panel to below the buttons on the second time you start editing.
KelseyNovacek1
Any idea on what is causing the editing bar to be repositioned to the top after a second edit is activate?  Any change I make usually results in the editing bar not show up after the changes.
KellyHutchins
I updated the fiddle to fix the issue with the editing toolbar being misplaced after stop/start editing.
