web application development
1938
6
07-15-2013 03:09 AM
mohammedmaina
Dear friends,
Could someone help pls, I installed arcgis server but launch the server manager and couldn't find 'create web application tab'' and don't know where to go again.
ManojrajTeli
Hello mainam,
If you are working with 10.1 ArcGIS server then I fear that module is removed from 10.1 . It was present with predecessor that is 10.0 ArcGIS server.
MustafaOgurlu
Hello Mainam,
You can open 'create web application tab' from ArcGIS Web Applications Manager 10.1 site from this url:
http://<Server Name>/<Instance Name>/Manager/login.aspx
Like
http://myserver/ArcGIS/Manager/login.aspx
mohammedmaina
Hello mainam,
Yes i am working with 10.1 and hope that I will be better for web application development. Any way how do I built the web application using 10.1 any clue, eg link or supporting doc.
i appreciate your efforts
thanks
maina
mohammedmaina
Hello Mainam,
Like
Sure i use http://localhost:6080/arcgis/manager/login.html, but after login as admin yet i can't see the "create web application tab" .how do I create web application using arcgis for server 10.1? I appreciate your efforts.
Maina
MustafaOgurlu
Its not http://localhost:6080/arcgis/manager/login.html           It must be http://localhost:6080/arcgis/manager/login.aspx
Could you see the "ArcGIS Web Applications for the Microsoft .NET Framework" at;
Start --> All Programs --> ArcGIS --> "ArcGIS Web Applications for the Microsoft .NET Framework"  -->  ArcGIS Web Applications Manager - arcgis
If not, you may not installed the "ArcGIS Web Applications for the Microsoft .NET Framework"
mohammedmaina
I only have arcgis server 10.1 and i want to built the application using JavaScript API. When i log into the manager as admin I only saw Http://localhost:6080/arcgis/manager. html. I didn't install .net framework.
