Ways to identify an ArcGISDynamicMapServiceLayer / non-Feature Layer
3932
10-09-2014 07:13 PM
XavierThay
Hi all,
currently I am having difficulties identifying the type of object to use when retrieving layers.
This is done in Javascript / JQuery front end & Java MVC / Hibernate controller mid tier.
I am hitting a REST service to grab said layer info, majority of the layers are of type "Feature Layers".
Which is loaded from an ARCGis backend and loaded into a new "esri.layers.FeatureLayer" Javascript object.
Like this:
var featureLayer = new esri.layers.FeatureLayer(url, { [options] };
This however does not work smoothly with other layers (e.g. in particular "Annotation Layers")
For Annotation Layers, I need to use the esri.layers.ArcGISDynamicMapServiceLayer(url) Javascript object.
var dynamicLayer = new esri.layers.ArcGISDynamicMapServiceLayer(url);
And here lies my problem: I currently have no way to identify if said object is a "Feature Layer" or any other type of Layer.
I was wondering if I could load the layer into an ArcGISDynamicMapServiceLayer Object and ues its properties to see if it is indeed a non-Feature Layer, but the methods / fields for the class seem rather lacklustre.
TLDR: Anyone knows of a way of identify an ArcGISDynamicMapServiceLayer layer loaded from REST?
Sincerely,
Xavier
KenBuja
MVP Esteemed Contributor
You can use esri.request on the service to get more information about it, including layer type. Take a look at this discussion.
