Want to driving direction between two points on map
2184
04-19-2017 05:06 AM
AdarshSharma
Hello, i m new in network analysis and I want to driving direction in this example can any one tell me how to get driving direction using this example.
<!DOCTYPE html>
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8">
<meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
<title>Multiple Routes</title>
<link rel="stylesheet" href="https://js.arcgis.com/3.20/dijit/themes/claro/claro.css">
<link rel="stylesheet" href="https://js.arcgis.com/3.20/esri/css/esri.css">
<script src="https://js.arcgis.com/3.20/"></script>
<script>
      require
"esri/urlUtils",
"esri/config",
"esri/map",
"esri/graphic",
"esri/tasks/RouteTask",
"esri/tasks/RouteParameters",
"esri/tasks/FeatureSet",
"esri/symbols/SimpleMarkerSymbol",
"esri/symbols/SimpleLineSymbol",
"esri/Color",
"dojo/_base/array",
"dojo/on",
"dojo/dom",
"dijit/registry",
"dijit/layout/BorderContainer",
"dijit/layout/ContentPane",
"dijit/form/HorizontalSlider",
"dijit/form/HorizontalRuleLabels"
], function (
        urlUtils
, esriConfig, Map, Graphic, RouteTask, RouteParameters,
FeatureSet, SimpleMarkerSymbol, SimpleLineSymbol,
Color, array, on, dom, registry
var map, routeTask, routeParams, routes = [];
var stopSymbol, barrierSymbol, routeSymbols;
var mapOnClick_addStops_connect, mapOnClick_addBarriers_connect;
        urlUtils
.addProxyRule({
          urlPrefix
: "route.arcgis.com",
          proxyUrl
: "/sproxy/"
        map
= new Map("map", {
          basemap
: "streets",
          center
: [-122.416, 37.802],
          zoom
: 15
        routeTask
= new RouteTask("https://route.arcgis.com/arcgis/rest/services/World/Route/NAServer/Route_World");
        routeParams
= new RouteParameters();
        routeParams
.stops = new FeatureSet();
        routeParams
.barriers = new FeatureSet();
        routeParams
.outSpatialReference = {"wkid":102100};
        routeTask
.on("solve-complete", showRoute);
        routeTask
.on("error", errorHandler);
        stopSymbol
= new SimpleMarkerSymbol().setStyle(SimpleMarkerSymbol.STYLE_CROSS).setSize(15);
        stopSymbol
.outline.setWidth(3);
        barrierSymbol
= new SimpleMarkerSymbol().setStyle(SimpleMarkerSymbol.STYLE_X).setSize(10);
        barrierSymbol
.outline.setWidth(3).setColor(new Color([255,0,0]));
        routeSymbols
"Route 1": new SimpleLineSymbol().setColor(new Color([0,0,255,0.5])).setWidth(5),
"Route 2": new SimpleLineSymbol().setColor(new Color([0,255,0,0.5])).setWidth(5),
"Route 3": new SimpleLineSymbol().setColor(new Color([255,0,255,0.5])).setWidth(5)
//button click event listeners can't be added directly in HTML when the code is wrapped in an AMD callback
        on
(dom.byId("addStopsBtn"), "click", addStops);
        on
(dom.byId("clearStopsBtn"), "click", clearStops);
        on
(dom.byId("addBarriersBtn"), "click", addBarriers);
        on
(dom.byId("clearBarriersBtn"), "click", clearBarriers);
        on
(dom.byId("solveRoutesBtn"), "click", solveRoute);
        on
(dom.byId("clearRoutesBtn"), "click", clearRoutes);
//Begins listening for click events to add stops
function addStops() {
          removeEventHandlers
= map.on("click", addStop);
//Clears all stops
function clearStops() {
          removeEventHandlers
for (var i=routeParams.stops.features.length-1; i>=0; i--) {
            map
.graphics.remove(routeParams.stops.features.splice(i, 1)[0]);
//Adds a stop. The stop is associated with the route currently displayed in the dropdown
function addStop(evt) {
          routeParams
.stops.features.push(
            map
.graphics.add(
new esri.Graphic(
                evt
.mapPoint,
                stopSymbol
{ RouteName:dom.byId("routeName").value }
//Begins listening for click events to add barriers
function addBarriers() {
          removeEventHandlers
= on(map, "click", addBarrier);
//Clears all barriers
function clearBarriers() {
          removeEventHandlers
for (var i=routeParams.barriers.features.length-1; i>=0; i--) {
            map
.graphics.remove(routeParams.barriers.features.splice(i, 1)[0]);
//Adds a barrier
function addBarrier(evt) {
          routeParams
.barriers.features.push(
            map
.graphics.add(
new esri.Graphic(
                evt
.mapPoint,
                barrierSymbol
//Stops listening for click events to add barriers and stops (if they've already been wired)
function removeEventHandlers() {
if (mapOnClick_addStops_connect) {
.remove();
if (mapOnClick_addBarriers_connect) {
.remove();
//Solves the routes. Any errors will trigger the errorHandler function.
function solveRoute() {
          removeEventHandlers
          routeTask
.solve(routeParams);
//Clears all routes
function clearRoutes() {
for (var i=routes.length-1; i>=0; i--) {
            map
.graphics.remove(routes.splice(i, 1)[0]);
          routes
//Draws the resulting routes on the map
function showRoute(evt) {
          clearRoutes
          array
.forEach(evt.result.routeResults, function(routeResult, i) {
            routes
.push(
              map
.graphics.add(
                routeResult
.route.setSymbol(routeSymbols[routeResult.routeName])
var msgs = ["Server messages:"];
          array
.forEach(evt.result.messages, function(message) {
            msgs
.push(message.type + " : " + message.description);
if (msgs.length > 1) {
            alert
(msgs.join("\n - "));
//Reports any errors that occurred during the solve
function errorHandler(err) {
          alert
("An error occured\n" + err.message + "\n" + err.details.join("\n"));
</script>
</head>
<body class="claro">
    Select route name:
<select id="routeName">
<option value="Route 1">Route 1</option>
<option value="Route 2">Route 2</option>
<option value="Route 3">Route 3</option>
</select> to
<button id="addStopsBtn">Add Stops</button>
<button id="clearStopsBtn">Clear Stops</button>
<button id="addBarriersBtn">Add Barriers</button>
<button id="clearBarriersBtn">Clear Barriers</button>
<button id="solveRoutesBtn">Solve Routes</button>
<button id="clearRoutesBtn">Clear Routes</button>
<br /><br />
<div id="map" style="width:600px; height:400px; border:1px solid #000;"></div>
<ol>
<li>Select a route name from the drop down.</li>
<li>Click 'Add stops', then click on map to add stops to route.</li>
<li>Click the 'Add Barriers', then click on map to add barriers.</li>
<li>Optionally, repeat the above steps to add more routes.</li>
<li>Click the 'Solve Routes' to solve.</li>
</ul>
<p>Any server error messages will be displayed in an alert box.</p>
</body>
</html>
by Anonymous User
Not applicable
Hello,
Check  profile image and create model builder GP service and use it in you application developed.
I have used it in our application developed using ArcGIS viewer for flex (flexviewer)
Ahmedabad 10K Map
patel1684
let me know if you require more details.
AdarshSharma
Actually i want to driving direction between two stop point using network analysis arc gis api for javascript. like this
