versioning of dojo.
5682
11
12-10-2013 09:19 AM
DorothyMortenson
I have made two applications that I want to combine.
The first was a test to develop the web map I want.  I use the
<script src="http://js.arcgis.com/3.7/"></script>
The second is one that I developed with the dijit/layout/BorderContainer, ContentPane, TabContainer, TabController, AccordionContainer. In other words, the second has all of the panels laid out. Looks nice.  It uses
<script src="http://ajax.googleapis.com/ajax/libs/dojo/1.8.1/dojo/dojo.js"></script>
I have also tried it with
<script src="//ajax.googleapis.com/ajax/libs/dojo/1.9.1/dojo/dojo.js"></script>
Both work.
When I try to put even a simple map into the second application, and have to add the
, the layout goes bad, like it doesn't know what to do with the containers.
Any suggestions?
Dorothy
KellyHutchins
Esri Notable Contributor
Dorothy,
There is an issue with using lang="en" along with layout dijits. If you remove this from your test case the app loads correctly when using the JSAPI. You can find more details on the problem by viewing the post by Adrian Marsden in this thread:
http://forums.arcgis.com/threads/74483-ESRI-Javascript-API-3.3
Here's the relevant bit:
Using lang="en" can break apps that use when using layout dijits and data-dojo-config(or dojoConfig) locale or extraLocale is not set. The recommended fix is to set locale or extraLocale on data-dojo-config or remove the lang="en" attribute. The specific error seen when this is an issue is "dojo/parser:arse() error TypeError" in Chrome and "TypeError: _72f(...) is undefined" in Firefox. More information is available in the Dojo bug tracker:http://trac.dojotoolkit.org/ticket/15630#comment:7http://trac.dojotoolkit.org/ticket/15768#comment:6
DorothyMortenson
You gotta be kidding me. Stick a sharp stick in my eye.
Thank you so much! I NEVER would have found that.
You just made my day.
