Version 4.24 -> 4.25 or 4.26 - Default generated feature service query WHERE clause is no longer the same
1755
03-06-2023 06:21 PM
YimYean
Hello,
I've been testing our version 4.11 until 4.26 to try to see where things changed and it looks like in 4.25+ the generated feature service query has changed.
Before:
After: The UPPER has changed to LOWER and the LIKE clause no longer includes the % at the beginning.  Is this expected change or bug?  If a bug how would I go about overriding it to perform custom query?
Best,
Yim
JoelBennett
MVP Regular Contributor
It seems likely you're seeing this in relation to the Search widget.  If that's the case, please see this thread.
UndralBatsukh
Hi there,
Do you have a reproducible case for this? I am not able to reproduce what you are describing here. I tested it and the following code
document.getElementById("queryButton").addEventListener("click", ()=> {
  const where = "UPPER(STATE_NAME) LIKE 'Miss%'"
  featureLayer.queryFeatures({where: where}).then((results)=>{
    console.log(results)
results in this query.
YimYean
Thanks @UndralBatsukh for the reply, it seems like my issue is related to the issue that @JoelBennett commented and has more details into the issue.
JoelBennett
