Verify if XY is inside polygon
16059
40
02-06-2017 01:23 PM
jaykapalczynski
Honored Contributor
Is there a way via JS or Python to simply pass an XY to a function and determine if inside or outside a polygon (from a map Service)
I need to do this for Decimal Degrees, DMS, UTM etc.
I can do it like below BUT I would have to list out EVERY node and trying to do this for a complete state
function inside(point, vs) {
    var x = point[0], y = point[1];
    var inside = false;
    for (var i = 0, j = vs.length - 1; i < vs.length; j = i++) {
        var xi = vs[i][0], yi = vs[i][1];
        var xj = vs[j][0], yj = vs[j][1];
        var intersect = ((yi > y) != (yj > y))
            && (x < (xj - xi) * (y - yi) / (yj - yi) + xi);
        if (intersect) inside = !inside;
    return inside;
var polygon = [[4040958.21,261090.239],[4399737.773,261090.239],  [4399737.773,1004118.285],[4040958.21,1004118.285]]
<!--// The below are two examples.  One of them is inside the other is outside to bounding box
// inside -->
test = inside([ 4147263, 646445.066 ], polygon); // true
<!-- // outside -->
test = inside([ 4537048, 694061 ], polygon); // false
alert(test);
RobertScheitlin__GISP
Jay,
   Assuming that the query result would return one polygon (the one that you want to test the points against) then you would just use:
function addPointsToMap(results) {
   var polygon = results.features[0].geometry;
jaykapalczynski
Honored Contributor
Something like this?
    require([
        "esri/tasks/query", "esri/tasks/QueryTask"],
     function (
    Map, Query, QueryTask) {
     parser.parse();
     //Geometry Service
     var geometryService = new GeometryService("http://sampleserver5.arcgisonline.com/arcgis/rest/services/Utilities/Geometry/GeometryServer");
     var query = new Query();
     var queryTask = new QueryTask( MY MAP SERVICE URL );
     query.outSpatialReference = {wkid:26917}; // UTM Zone 17 N
     query.returnGeometry = true;
     queryTask.execute(query, getPoints);
        var pnt = new Point(4147263, 646445.066, new SpatialReference({ wkid: your datas wkid # }));
       if (polygon.contains(pnt)){
               console.info("point is inside polygon");
          }else{
               console.info("point is NOT inside polygon");
Jay,
   That is pretty good assuming that you are omitting some requires and other code like the query.where clause for brevity sake.
jaykapalczynski
Honored Contributor
Can I use something like below to get the polygon...there will only be 1
query.where = 1=1;
Sure if the map service will only have one that will be fine.
jaykapalczynski
Honored Contributor
OK maybe you can see something....
I get my map and I get my button.
I click the button and it ALERTS me "your in"
SO that had to have passed through the execute Function and then into the getPoints Function
Seems to be blowing up in the If Else Statement.....Thoughts?  I dont get any of the alerts from the If Else statement
<!DOCTYPE html>
<html>
<head>
  <title>Advanced Draw</title>
  <link rel="stylesheet" href="http://js.arcgis.com/3.19/dijit/themes/claro/claro.css">
  <link rel="stylesheet" href="http://js.arcgis.com/3.19/esri/css/esri.css">
  <script src="http://js.arcgis.com/3.19/"></script>
  <script>
    require([
        "esri/map", "dojo/ready", "dojo/parser", "esri/tasks/GeometryService", "esri/tasks/query", "esri/tasks/QueryTask",
          "dojo/dom", "dojo/on", "dojo/domReady!"],
     function (
    Map, ready, parser, GeometryService, Query, QueryTask, dom, on) {
     ready(function(){
     parser.parse();
     //Geometry Service
     var geometryService = new GeometryService("https://sampleserver5.arcgisonline.com/arcgis/rest/services/Utilities/Geometry/GeometryServer");
     //Add the Map/////////////////////////////////////////////////
     map = new Map("map", {
         basemap: "topo",
         center: [-80.734, 28.297],
         zoom: 10
    function execute () {
          var queryTask = new QueryTask("https://xxxxxx/arcgis/rest/services/Public/VirginiaBoundary/MapServer/0");
          query.where = "1=1";
     function getPoints(results) {
        alert("your in");
        var pnt = new Point(4147263, 646445.066, new SpatialReference({ wkid:26917}));
               alert("point is inside polygon");
          }else{
               alert("point is NOT inside polygon");
           //write "Get Details" button's click event
     on(dom.byId("runQuery"), "click", execute);
  </script>
</head>
<body class="claro">
  <input type="button" value="Verify XY" id="runQuery" />
  <div id="map" style="width:600px; height:600px; border:1px solid #000;"></div>
</body>
</html>
jaykapalczynski
Honored Contributor
Think I got it....As you mentioned earlier I was missing Requires....Once I get this working will post all code....Thanks for your help and guidance Robert
Jay,
   Don't forget to mark this question as answered by clicking on the "Correct Answer" link on the reply that answered your question.
jaykapalczynski
Honored Contributor
Will do just finalizing my code to post here and make sure everything works...Cheers
jaykapalczynski
Honored Contributor
Last question...I am trying to test if inside my state.  UTM and Lat Long work great...but now looking at DMS and DMM
I can test on the DD fine...but it breaks when I try the other 2.  All locations below are in my state
DDD° MM' SS.S"      36° 51' 47.3" N 76° 0' 56.8" W
Degrees, Minutes and Seconds
DDD° MM.MMM'       36° 51.7884' N 76° 0.94668' W
Degrees and Decimal Minutes
DDD.DDDDD°           36.863140, -76.015778
Decimal Degrees
I try and type in the DMS and DMM in the format below but it fails everytime....BUT I can enter the DD fine and it works.
I enter them into 2 textboxes on my webpage as such
DMS
36 51 47.3   76 0 56.8
DMM
36 51.7884  76 0.94668
Any thoughts?
          var queryTask = new QueryTask("https://xxxx.gov/arcgis/rest/services/Public/Boundary/MapServer/0");
          if(document.getElementById('UTM17N').checked) {
          }else if(document.getElementById('DD').checked) {
               query.outSpatialReference = {wkid:4326};
          }else if(document.getElementById('DMS').checked) {
          }else if(document.getElementById('DDM').checked) {
          // FINISH THE QUERY PARAMETERS AND CALL THE FUNCTION TO TEST
          query.outFields = ["*"];
        var XValue = document.getElementsByName('XCoord')[0].value
        var YValue = document.getElementsByName('YCoord')[0].value
        var TextBoxpnt = new Point((XValue), (YValue));
        if (polygon.contains(TextBoxpnt)){
               document.getElementById("p1").innerHTML = "point is inside polygon";
          }else{
               document.getElementById("p1").innerHTML = "point is NOT inside polygon";
