Vector tile layer not retaining current map extent in ArcGIS JS 4.0
2253
07-12-2016 08:48 AM
MuktaPuri
We have found this issue where if have multiple layers (including a vector layer) on the map and if we do the following, the current map extents are not applied to the vector layer:
  • Disable vector tile layer (set visible property to false).
  • Pan the map.
  • Enable the vector tile layer.
  • New map extents are not applied to the vector tile layer.
Here is a JS fiddle where you can try this out: JSFiddle
Is there a workaround/fix to this issue?
As we require multiple layers that can be enabled/disabled on the map for our project, it is critical for our project that we get this working.
Tags (1)
ReneRubalcava
Esri Frequent Contributor
This would be a bug in 4.0. You can currently work around the issue by setting the view.extent to itself immediately after setting the visibility.
    on(layersElement, ".layers-item:click", function(e) {
      var node = document.querySelector(".layers-item");
      node.classList.toggle("visible-layer");
      tileLyr.visible = !tileLyr.visible;
      // add this line
      view.extent = view.extent;
Thanks!
ReneRubalcava
      // add this line
Thanks!
MuktaPuri
Thank You! That worked!
