v3.1 : Uncompressed Files
2912
6
08-07-2012 09:00 AM
__Rich_
Are the uncompressed versions of the code gone for good?
(if so it's going to make debugging quite a bit more difficult)
RyanTwilley
The chrome dev tools are a decent substitute. There's a 'pretty print' button at the bottom (looks like this - {}) that expands the code and updates links to errors, etc. You still have a lot of functions named stuff like '_1cc', but it's somewhat workable.
__Rich_
Thanks, Ryan, yep, pretty-printing does help but it's sooooo much easier to see the un-minified code complete with comments etc.
The reason I was asking is that the zip files are missing some other items (e.g. the handlers) and there were mistakes in the instructions etc. so I was wondering whether this was a deliberate omission or an oversight?
P.S. For Firefox devs try this javascript deminifier, seems to play nicely with Firebug.
ReneRubalcava
Esri Frequent Contributor
The ArcGIS JavaScript unbuilt source is not available, and as far as I know has never been available.
There is a posting up at the ideas site for this suggestion though, so go upvote it and let's see what goes from there.
http://ideas.arcgis.com/ideaView?id=087E00000004JOzIAM
__Rich_
Oh really?  What are these then?
[ATTACH=CONFIG]16875[/ATTACH]
Have you ever looked inside the *js.uncompressed.js files?  Have you ever adjusted your default handler to return the uncompressed layer file?
In this case I don't think that should be necessary and I don't think it's the appropriate mechanism.
All this topic needs is a yes/no answer from ESRI at this stage.
ReneRubalcava
I always thought that code had already been minified. meaning the var names are obfuscated and comments have been removed. I haven't pulled those before, but now I will, thanks.
No wonder, last dl I have is 2.8 where those files were not included, at least not when I downloaded them. They're in 3.0 though. That's fun.
__Rich_
I always thought that code had already been minified. meaning the var names are obfuscated and comments have been removed. But hey, if they were available before then I agree.
I think we're talking about two different things, so my bad.
No worries, that probably means you haven't needed to delve too far into the inner workings...which is a good thing from your perspective! 🙂
(re. Ideas - I'm sure some 'ideas' do get incorporated but I've got a couple that were 'promoted' a couple of years ago that still aren't implemented yet, guess they aren't good enough, still makes me a bit reluctant to bother with that mechanism)
