UTM NAD 1927 to DMS
1834
02-26-2013 03:33 AM
Udaya_BhaskerCheerala
Hi All,
I have requirement to convert UTM NAD 1927 Northing (4804172), Esting(753352) to Geographic coordinatesystem(Degrees Minutes, Seconds).
Iam doing like below
m_mapPoint[0] = new esri.geometry.Point(4804172, 753352, new esri.SpatialReference({ wkid: 26712 }));
var geogPt = esri.geometry.webMercatorToGeographic(m_mapPoint[0]);
gsvc.project([geogPt], outSRgc83, convrtCord83);
when I project the point I am getting result as NaN. But It's equivalent DMS should be 42 21' 58.42'', 107 52' 29.28''
and map point should be 42.5698, -107.5229
Please help me how to resolve it.
Uday
ReneRubalcava
Esri Frequent Contributor
I'm a little confused at these two lines.
wkid 26712 is not a web mercator projection. Web Mercator wkid is 102100 (and 102113? the two still throw me off).
esri.geometry.webMercatorToGeographic will convert it to 4326.
You should be able to skip the above step and go straight to the geometry service project() method specifying what output spatial reference you are looking for once you create your m_mapPoint[0].
Granted I haven't had a need to project very often beyond geographc and web mercator, so take this with a grain of salt.
It is working after changing the code as below.
var params = new esri.tasks.ProjectParameters();
// add array of points
params.geometries = m_mapPoint;
// Output Spatial Reference in lat/long (wkid 4326)
params.outSR = new esri.SpatialReference({wkid: 4326});
// run callback once the geometry service returns the reprojected results.
gsvc.project(params, callback, errback);
Thankyou very much.
Uday
