Using WorldDEM4Ortho layer to query elevation for a point
1227
12-07-2020 03:32 AM
LucasGauna
Hi guys,
I'm using this layer http://www.arcgis.com/home/item.html?id=7029fb60158543ad845c7e1527af11e4,  with uses SRTM.
But i've found that Arcgis supports Airbus WorldDEM4Ortho, there is a way to use a elevation layer with this information?
JohnGrayson
Esri Alum
I believe Terrain 3D is already using it; there's a link in the item description you mention above to this other item which describes the 'Elevation Coverage' of the item you are using.  In this list I see WorldDEM4Ortho listed at 24 meters for the World.
JohnGrayson
Esri Alum
