Using setScale(8000) and (12000) does not see map scale change
3287
12-28-2015 06:44 AM
fuliaoli
In my app, when I click scale(24000) and (12000), I see the map changes as scale changes. But from 8000 to 12000, there is no change.
Are there some fixed scale tiles set in ESRI base maps?  I don't have much experience of map documents.
Thanks in advance,
li
TimWitt2
Yes you are right, depending on the scale it loads new tiles.
TimWitt2
fuliaoli
Hi Tim,
Thanks a lot for your quick response.
Regards,
li
