Using "Current Location" by default in Directions widget (4x)
1801
01-12-2022 11:13 PM
ZA1
Hello,
Using the Directions widget I would like to:
  • Use Current Location as starting point by default
  • Auto-populate destination with some address
i.e.:
Unfortunately, I have not found properties in the documentation to do this.
Any help would be greatly appreciated.
Thank you
Noah-Sager
Hi @ZA1, unfortunately it is not currently possible to pre-populate the Directions widget with two different addresses or locations. However, we have some enhancements coming that might make this possible at a future release.
If you don't need the Directions widget, you could handle the routing and the turn-by-turn directions yourself using route: https://developers.arcgis.com/javascript/latest/api-reference/esri-rest-route.html
Noah-Sager
ZA1
Hi @Noah-Sager . Once again, thanks for the info, much appreciated! 🙂
Am I right in thinking that pre-population of fields in JSAPI 4 is generally an issue?
Previously I struggled to find a way to automatically populate fields in the Create Workflow of the Editor widget. (link to post)
