Using queryTask and zooming into a geometry
1553
05-27-2013 10:25 PM
PrasannaRaghavendar
I am trying to get the geometry of the polygon using UNIQPOLYID.
UNIQPOLYID is the display field.
function searchGeometry(polyId){    queryTask = new esri.tasks.QueryTask(URLGoesHere);    query = new esri.tasks.Query();    query.returnGeometry = true;    query.text = polyId;    queryTask.execute(query, queryResults); }  function queryResults(featureSet){    alert(featureSet.features); //undefined    //Should get the geometry of the feature and zoom into it. }
"featureSet.features" is undefined in my queryResults(featureSet). How should I get the the feature with the provided polyId so that I can zoom in to the geometry.
VinayBansal
Check with rest url , if you are getting results.
http://<yourserver>/arcgis/rest/services/<Map_Service>/Mapserver/layerid
VinayBansal
PrasannaRaghavendar
I got the geometry when I included layerId.
 var resultSet = featureSet.features;
 var shape = resultSet[0].geometry;
            if(shape.type==='polygon'){
         var featureExtent=shape.getExtent();
         map.setExtent(featureExtent);
     }else{
         alert("Shape is not a polygon");
Though I set feature Extent to map extent. The slider zooms to the fullest and I get to see only "Map Data Not Available". Why is that? I want the slider to just zoom on the polygon.
VinayBansal
If you got your answer, then do mark the post as answered.
And regarding your second query, this may happen in many scenarios....
like projection of geometry is different than that of map.
Map is zooming to location where base map is not available.
