Using map components - how to set spatialReferenceLocked on view
1004
09-02-2025 08:37 AM
AJasper
I'm using arcgis/map-components in my app and I'm having a bit of a problem setting the spatialReferenceLocked of the map view. See code below (TypeScript/Angular).
    const sr = new SpatialReference({
      wkid: 27700,
    this.arcgisMap = this.mapViewElement?.nativeElement as ArcgisMap;
    let baseLayer: Layer;
    if (environment.baseLayerType === 'VectorTileLayer') {
      baseLayer = new VectorTileLayer({
        url: environment.baseMapUrl,
        title: 'Great Britain',
    } else {
      baseLayer = new TileLayer({
    const extent = new Extent({
      xmin: -100000,
      ymin: -30000,
      xmax: 710000,
      ymax: 1250000,
      spatialReference: sr.clone(),
    const map = new Map({
      basemap: new Basemap({
        baseLayers: [baseLayer],
    this.arcgisMap.extent = extent;
    this.arcgisMap.constraints.maxScale = 0;
    this.arcgisMap.constraints.lods = TileInfo.create({
      spatialReference: extent.spatialReference.clone(),
    }).lods;
    this.arcgisMap.view.spatialReferenceLocked = true;
    this.arcgisMap.map = map;
 On line 41 where the spatialReferenceLocked property is being set to true (filters out basemaps as using basemap gallery) it errors with the error
[esri.core.Accessor] cannot assign to construct-only property 'spatialReferenceLocked'
I cannot figure out how I set this property, any help would be greatly appreaciated.
Adam
AJasper
To fix this issue, update to v4.34.x of map-components. A new property has been added to ArcgisMap that allows you to lock the spatial reference. Line 41 of the code in the original post should read:
this.arcgisMap.spatialReferenceLocked = true;
AJasper
