Using javascript to GeoCode address and get a UID back
1320
07-30-2020 01:16 PM
AlGrant
Hello,
I asked a similar question on the REST API forum, but what I am trying to do, possibly with Javascript is the geocode and address, get the normalised dfata back, and store it locally in a MySQL database.
Other geocoding systems will return in the result a uniquie identifier (UID) - so that if that address is queried again in future it can be linked to the existing location rather than a new entry created.
Can the javascript API return a UID in the results for an address?
Thanks
Al
shaylavi
Hi AI,
I don't know much about other geocode systems as you mentioned, but you need to understand better how a geocoder works in ESRI to know how to implement such a solution, assuming that's what you're after.
Short long story, a geocoder is a quicker way (using an indexed table) to find information for coordinates. When creating the geocoder, you also define its output structure, based on the available data that geocoder is attached to (which is an indexed table).
Normally, a geocoder will return the data based on the coordinates. You can build your own geocoder and decide that it returns some kind of ID, but if there's an internal cache mechanism to monitor your calls and retrieve previous values? definitely not out of the box, but you can probably create one of your own. Also, when using ESRI's world geocoder / public geocoders, there are some legal requirements for billing purposes when using the geocoder over a certain amount of calls per month, so I don't see how that can work with the mechanism you mentioned when calling a public geocoder.
There are online resources you can read about it - What is geocoding?—ArcMap | Documentation
Shay.
Shay
