Using JavaScript API, panning sometimes gets stuck, unable to stop panning
2807
10-20-2014 01:47 PM
CraigPennington
I'm using ArcGis 3.10.  When a user uses the mouse to pan, occasionally they get stuck in a mode where, after releasing the mouse button, further mouse movement continues to pan.  It seems the mouseup or dragend event is somehow missed.
Are others seeing this?  Is there a solution?  I did see a post with this problem using Silver-light.
KenBuja
MVP Esteemed Contributor
Take a look at this discussion, which talks about event propagation issues.
DavidFriedrich
This problem is fairly easy to reproduce using one of the samples:
https://developers.arcgis.com/javascript/jssamples/fl_hover.html
It seems to happen with IE more so than Chrome or Firefox.
