Using Identity Manager to verify Application Access programmatically without redirect.
1929
03-12-2024 11:20 AM
AndrewMurdoch1
Good Day
I'm trying to verify my application settings without having to direct through the login system.
I have a page with the following formation on it (this is an Angular Application):
Server URL
App ID
App Secret
Server Type:  Online vs Enterprise
Token URL
What I want, is to pass the data into the Identity Manager and have it give me back a successful response, to verify the data is correct.   Every time I call the Identity Manager, with this flow:
            const info = new OAuthInfo({
                appId: portalConfig.appId,
                flowType: 'auto',
                popup: popup
            IdentityManager.registerOAuthInfos([info]);
            IdentityManager.getCredential(portalConfig.serverURL + '/sharing').then(() => {
                IdentityManager.checkSignInStatus(portalConfig.serverURL + "/sharing").then(() => {
                    r(portalConfig.serverURL);
                }).catch((error) => {
                    console.log('Error - Identity Manager - Check Sign In Status');
                    console.log(error);
                    j(error);
                console.log('Error - Identity Manager - Get Credential');
                console.log(error);
                j(error);
I get redirected to a window that asks if I want to allow that connection
How can I bypass this Windows?  I'm using ArcGIS Code 4.29.7.
Thanks
AndrewMurdoch1
I found a workaround, if you ever run into this, but it requires a username / password.
const param = {
                    username: this.username,
                    password: this.password
                // @ts-ignore
                esriId.generateToken(serverInfo, param).then((tokenRes: any) => {
                    esriId.registerToken({server: serverURL, token: tokenRes.token});
                    esriId.checkAppAccess(serverURL, appId).then((getCredRes) => {
                        r(getCredRes);
                        console.log('Error - Checking App Access');
                        console.log(error);
                        j(error);
                    r(serverURL);
                    console.log('Error - Generating Token');
                    console.log(error);
                    j(error);
Then you'll be able to use the connection without getting stopped :).
AnjulPandey
An instance of ArcGISIdentityManager can be created with several different methods including helper methods for OAuth 2.0 user authentication workflows.
import { ArcGISIdentityManager } from "@esri/arcgis-rest-request"; ArcGISIdentityManager.beginOAuth2({ clientId: "YOUR_CLIENT_ID", redirectUri: "YOUR_REDIRECT_URI" }).then((manager) => { console.log(manager); });
Refer this link for more details -
https://developers.arcgis.com/arcgis-rest-js/authentication/
It is not recommended to construct ArcGISIdentityManager directly. Instead there are several static methods used for specific workflows. The 2 primary workflows relate to oAuth 2.0:
