Using color in a SimpleFillSymbol
1510
05-08-2012 04:38 PM
JamesVillanueva
I have been looking through the documentation, and running some tests. Is true that when you're using a SimpleFillSymbol with anything besides the solid setting for style, your fill color will be ignored and the hatched lines will always be black. This could simple be a mistake on my part coding.
BrettGreenfield__DNR_
I'm wondering the same thing - anyone have an answer?  I'm trying to use the FORWARD_DIAGONAL style, but the lines are always black.  Changing the FORWARD_DIAGONAL to SOLID gives me the color I wanted; so how do I make the diagonal lines the right color?
SimonUyttendaele
This issue is linked to this one.
Please vote upon the following idea which is precisely about this in order to promote the following solution.
Regards
