Using both the navigation and drawing toolbar
1297
06-16-2011 10:00 AM
SwenWaschk
I'm having a bit of a problem with getting my navigation toolbar to work. My drawing toolbar on the other hand is working just fine.
dojo.require("esri.map");
dojo.require("esri.dijit.Scalebar");
dojo.require("esri.dijit.OverviewMap");
dojo.require("esri.toolbars.draw");
dojo.require("esri.toolbars.edit");
dojo.require("esri.toolbars.navigation");
 var map, navToolbar, toolbar, editToolbar, ctxMenuForGraphics, selected;
    function init() {
  esriConfig.defaults.map.slider = {left : "23px", top : "65px", width : null, height : "200px"};
        var initExtent = new esri.geometry.Extent({"xmin":-11613537,"ymin":1962657,"xmax":10204648,"ymax":12118386,"spatialReference":{"wkid":102100}});
        map = new esri.Map("map", {extent: initExtent , logo: false, slider: true});
        //resize the map when the browser resizes - view the 'Resizing and repositioning the map' section in
        //the following help topic for more details http://help.esri.com/EN/webapi/javascript/arcgis/help/jshelp_start.htm#jshelp/inside_guidelines.htm
        var resizeTimer;
        dojo.connect(map, 'onLoad', function(theMap) {
          dojo.connect(dijit.byId('map'), 'resize', function() { //resize the map if the div is resized
            clearTimeout(resizeTimer);
            resizeTimer = setTimeout(function() {
              map.resize();
              map.reposition();
            }, 500);
    //add the scale bar
    var scalebar = new esri.dijit.Scalebar(
     map : map,
     scalebarUnit : 'metric'
    //add the overview map
          var overviewMapDijit = new esri.dijit.OverviewMap(
     map : map,
     attachTo : "bottom-right",
     color : "#769dc0",
     visible : true
   overviewMapDijit.startup();
  dojo.connect(map, "onLoad", createToolbarAndContextMenu)
  dojo.connect(map, "onLoad", createToolbar);
        //Add the topographic layer to the map. View the ArcGIS Online site for services http://arcgisonline/home/search.html?t=content&f=typekeywords:service
        var basemap = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer");
        map.addLayer(basemap);
 function createToolbarAndContextMenu(map) {
        // Create and setup editing tools
        editToolbar = new esri.toolbars.Edit(map);
        dojo.connect(map,"onClick", function(evt){
          editToolbar.deactivate();
        createMapMenu();
        createGraphicsMenu();
        //resize map when browser resizes
          resizeTimer = setTimeout( function() {
            map.resize();
            map.reposition();
          }, 500);
  function createNavToolbar(map){
    // Create and setup navigation tools
    navToolbar = new esri.toolbars.Navigation(map);
    dojo.connect(navToolbar, "onExtentHistoryChange", extentHistoryChangeHandler);
  function extentHistoryChangeHandler() {
        dijit.byId("zoomprev").disabled = navToolbar.isFirstExtent();
        dijit.byId("zoomnext").disabled = navToolbar.isLastExtent();
  function createMapMenu() {
        // Creates right-click context menu for map
        ctxMenuForMap = new dijit.Menu({
          onOpen: function(box) {
        /*ctxMenuForMap.addChild(new dijit.MenuItem({
          label: "Add Point",
          onClick: function addToMap (geometry) {
            map.showZoomSlider();
    var symbol = new esri.symbol.SimpleMarkerSymbol(esri.symbol.SimpleMarkerSymbol.STYLE_SQUARE, 10, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([255,0,0]), 1), new dojo.Color([0,255,0,0.25]));
                var graphic = new esri.Graphic(geometry, symbol);
    map.graphics.add(graphic);
        ctxMenuForMap.startup();
        ctxMenuForMap.bindDomNode(map.container);
    function createGraphicsMenu() {
        // Creates right-click context menu for GRAPHICS
        ctxMenuForGraphics = new dijit.Menu({});
        ctxMenuForGraphics.addChild(new dijit.MenuItem({
          label: "Edit",
          onClick: function() {
            if(selected.geometry.type !== "point"){
              editToolbar.activate(esri.toolbars.Edit.EDIT_VERTICES, selected);
            else{
              alert("Not implemented");
          label: "Move",
            editToolbar.activate(esri.toolbars.Edit.MOVE, selected);
          label: "Rotate/Scale",
              editToolbar.activate(esri.toolbars.Edit.ROTATE | esri.toolbars.Edit.SCALE, selected);
            else{
          label: "Style",
        ctxMenuForGraphics.addChild(new dijit.MenuSeparator());
          label: "Delete",
            map.graphics.remove(selected);
        ctxMenuForGraphics.startup();
        dojo.connect(map.graphics, "onMouseOver", function(evt) {
          // We'll use this "selected" graphic to enable editing tools
          // on this graphic when the user click on one of the tools
          // listed in the menu.
          selected = evt.graphic;
          // Let's bind to the graphic underneath the mouse cursor
          ctxMenuForGraphics.bindDomNode(evt.graphic.getDojoShape().getNode());
        dojo.connect(map.graphics, "onMouseOut", function(evt) {
          ctxMenuForGraphics.unBindDomNode(evt.graphic.getDojoShape().getNode());
 function createToolbar(themap) {
          resizeMap();
       toolbar = new esri.toolbars.Draw(map);
       dojo.connect(toolbar, "onDrawEnd", addToMap);
    function addToMap(geometry) {
        toolbar.deactivate();
         switch (geometry.type) {
            case "point":
              break;
            case "polyline":
              var symbol = new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_DASH, new dojo.Color([255,0,0]), 1);
              break;
            case "polygon":
              var symbol = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_DASHDOT, new dojo.Color([255,0,0]), 2), new dojo.Color([255,255,0,0.25]));
              break;
            case "extent":
              break;
 //Handle resize of browser
    function resizeMap(){
        resizeTimer = setTimeout(function(){
          map.resize();
          map.reposition();
        }, 500);
dojo.addOnLoad(init);
SwenWaschk
I found my error, it was actually pretty simple i forgot to add:
dojo.connect(map, "onLoad", createNavToolbar);
at the end of the function(init)
