Template picker don't render in div
1687
06-18-2011 10:41 PM
KristerVikström
Hi!
I'm using the template picker widget through javascript api v 2.3 and it works fine... some times. Now and then it just don't render in the div. If i do changes in the map on an existing feature (attribute or geometry) the process bar show up while saving the edits (The edits are saved to the database).
See the attached image.
Anyone who has the same experience or have any idea why i get this behavior?
I'm using ArcGIS server 10.0 and ArcSDE 9.3.1 sp1, IE 8.0.7600.16385
//KV
KristerVikström
This is how it looks like when it's working.... I have done nothing to the sourcecode...
