Using ArcGIS JS API From Different Host Kills Access to Widgets on Page
3066
08-05-2015 04:21 PM
ZianChoy
I would like to use a copy of the ArcGIS JavaScript API hosted on another server (say, ESRI's CDN) but I find that when I do that, I can no longer access any of the Dojo widgets on my page.
Has anyone found a workaround for the problem?
Sample code:
HTML File:
<!DOCTYPE html>
<html>
<head>
    <link rel="stylesheet" type="text/css" href="http://js.arcgis.com/3.14/dijit/themes/claro/claro.css">
    <link rel="stylesheet" type="text/css" href="http://js.arcgis.com/3.14/esri/css/esri.css">
    <script type="text/javascript" src="http://js.arcgis.com/3.14/"></script>
    <title>Map</title>
<script type="text/javascript" src="trivial.js"></script>
</head>
<body class="claro">
    <div id="content"
        data-dojo-type="dijit/layout/LayoutContainer"
        data-dojo-id="content">
        <div id="right_pane"
            data-dojo-type="dijit/layout/ContentPane"
            data-dojo-props="region:'right'"
            data-dojo-id="right_pane">
        <div data-dojo-type="dijit/layout/StackContainer" data-dojo-id="sidebar_stack_container">Abc</div>
  </div>
    </div>
</body>
</html>
Contents of trivial.js
require([
  "dojo/parser",
  "dojo/domReady!"
], function (
  parser,
  domReady) {
   parser.parse();
var test = sidebar_stack_container;
Resulting F12 Developer Tools Error Message:
ReferenceError: 'sidebar_stack_container' is undefined in domReady callback ReferenceError: 'sidebar_stack_container' is undefined
   at Anonymous function (http://data.firstwatch.net/workspace/trivial.js:8:2)
   at ha (http://js.arcgis.com/3.14/:22:464)
   at Anonymous function (http://js.arcgis.com/3.14/:23:202)
   at ia (http://js.arcgis.com/3.14/:23:89)
   at fa (http://js.arcgis.com/3.14/:23:144)
   at b (http://js.arcgis.com/3.14/:24:122)
   at e (http://js.arcgis.com/3.14/:160:433)
   at d (http://js.arcgis.com/3.14/:161:360)
      [functions]: ,
      __proto__: { },
      description: "'sidebar_stack_container' is undefined",
      message: "'sidebar_stack_container' is undefined",
      number: -2146823279,
      stack: "ReferenceError: 'sidebar_stack_container' is undefined
   at d (http://js.arcgis.com/3.14/:161:360)"
   "in domReady callback"
