Using a LabelLayer on map.graphics?
4414
05-29-2014 02:58 PM
DuncanNisbett
All examples I've seen when using the LabelLayer shows using a feature layer. I'm trying to figure out in my app is can I use the map.graphics layer as the layer set for the Label layer? When I try it now it fails and I'm wondering if there's a way to make it work. I was hoping to use this as I've used it in the past with a featurelayer for users adding graphics and it was great to show titles on the screen. When a graphic was added, boom, the label was shown. When a graphic removed, boom, the correlating label was also removed.
I know I can go old school and manually add text symbols to the map.graphics layer. But I was hoping for a more elegant solution if possible.
var symbol = new TextSymbol(); var renderer = new SimperRenderer(symbol); var labelLayer = new LabelLayer(); labelLayer.addFeatureLayer(map.graphics, renderer, "${TITLE}"); map.addLayer(labelLayer);
JakeSkinner
Esri Esteemed Contributor
Here is the code:
<!DOCTYPE html> <html>   <head>     <meta http-equiv="Content-Type" content="text/html; charset=utf-8">     <meta name="viewport" content="initial-scale=1, maximum-scale=1, user-scalable=no">     <title></title>     <link rel="stylesheet" href="https://community.esri.com//js.arcgis.com/3.9/js/esri/css/esri.css">     <style>       html, body, #map {         height: 100%; width: 100%; margin: 0; padding: 0;        }     </style>      <script src="//js.arcgis.com/3.9/"></script>     <script>       var map;            require([         "esri/map",          "esri/geometry/Extent",         "esri/layers/FeatureLayer",         "esri/layers/GraphicsLayer",          "esri/symbols/SimpleLineSymbol",         "esri/symbols/SimpleFillSymbol",         "esri/symbols/TextSymbol",         "esri/renderers/SimpleRenderer",          "esri/layers/LabelLayer",         "esri/geometry/Polygon",         "esri/InfoTemplate",         "esri/graphic",                  "dojo/on",          "esri/Color",         "dojo/domReady!"       ], function(         Map, Extent, FeatureLayer, GraphicsLayer,         SimpleLineSymbol, SimpleFillSymbol, TextSymbol, SimpleRenderer,         LabelLayer, Polygon, InfoTemplate, Graphic,         on,         Color       ) {          map = new Map("map", {           center: [-75.249, 38.485],           zoom: 9,           basemap: "gray"       });                          var sfs = new SimpleFillSymbol(SimpleFillSymbol.STYLE_SOLID,           new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID,           new Color([255,0,0]), 2),new Color([255,255,0,0.25])         )                            var singleRingPolygon = new Polygon([[-75.77, 38.45], [-75.77, 38.7], [-75.11, 38.7], [-75.11, 38.45], [-75.77, 38.45]])         var attr = {"Area":"Southern Delaware"};         var infoTemplate = new InfoTemplate("Location","Area: ${Area}");         var gra = new Graphic(singleRingPolygon, sfs, attr, infoTemplate);                 graphicsLayer = new GraphicsLayer();         graphicsLayer.add(gra);         map.addLayer(graphicsLayer);          // create a text symbol to define the style of labels         var textColor = new Color("#666");         var textLabel = new TextSymbol().setColor(textColor);         textLabel.font.setSize("14pt");         textLabel.font.setFamily("arial");         textLabelRenderer = new SimpleRenderer(textLabel);         var labels = new LabelLayer({ id: "labels" });                  labels.addFeatureLayer(graphicsLayer, textLabelRenderer, "${Area}");                  map.addLayer(labels);       });     </script>   </head>   <body>     <div id="map"></div>   </body> </html>
JakeSkinner
Hi Duncan,
Not sure if this is a valid solution for you, but I was able to get this to work by adding the graphics to a GraphicsLayer.  You can see an example here.
BhavinSanghani
The link you gave is not working for me. Can you paste your code here? It seems it's JSFiddle issues in their code.
JakeSkinner
Here is the code:
DuncanNisbett
Here is the code:
Brilliant! I have no idea why I never noticed that within the API documentation. But that code snippet was perfect. I'd buy you a beer if I could.
