User based Bookmarks
3549
05-21-2021 03:42 PM
RYANCARL
I have some questions about making user scoped Bookmarks using the ArcGIS JS API 4.x inside a web map application.
We have ArcGIS Enterprise and want to have Bookmarks that are associated to the users identity. So that when a user finds a location of interest they can save it for later.
Is there a way to do this? Or are Bookmarks only setup generically for all users?
Any information will be greatly appreciated.
BjornSvensson
Esri Alum
@RYANCARL- Bookmarks are typically stored within the webmap, so not for each user - unless they make a copy of the webmap.
For a custom app, you could create/store bookmarks in whichever way you want (and then use to populate the Bookmarks widget), but that would be your own custom code.
BjornSvensson
Esri Alum
RYANCARL
@BjornSvensson Thank you for getting back to me.
Does the ArcGIS JS API need a developer license from https://developers.arcgis.com/ when we have the ArcGIS Enterprise licenses and are setup on an isolated environment?
I am trying to wrap my head around the JS API documentation in regards to the API token and how it needs to be associated to a portal.
BjornSvensson
Esri Alum
RYANCARL
Thank you
