Use look up table to replace Feature Table values
760
12-07-2023 12:02 PM
MatthewDriscoll
I have two hosted service tables, table 1 is the production for a old and newly created permits.  Table 1 uses an index number field for its values.  Table 2 has the index number field and a description values field.  Is it possible to replace the description values, queried from table 2, to use as the value in replacement for a column in a Feature Table of table 1?  Essential I need to users to see the description in that column instead of the index number.
