URL Parameters
22997
20
05-27-2010 07:32 AM
AndyBurns
Hi All
Does anyone have any documentation or any ideas about what URL parameters we can pass to the javascript API?
thanks
JohnGrayson
Esri Alum
Since this functionality is application specific, here's one example of how I've done it before:
  var urlObject = esri.urlToObject(document.location.href);
  if (urlObject.query) {
    if (urlObject.query.lon && urlObject.query.lat) {
      var lon = parseFloat(urlObject.query.lon);
      var lat = parseFloat(urlObject.query.lat);
      var initialLocation = esri.geometry.geographicToWebMercator(new esri.geometry.Point(lon, lat, new esri.SpatialReference({
        wkid: 4326
      map.centerAndZoom(initialLocation, 14);
RajasekharReddyMayaluru
Hi Grayson,
I'm new to this API, I'm trying to integrate with Arc GIS with my web application .
Can you please send me full example (with some URL with static values),So that i can customize it.
I'm looking for an example to locate a point using Arc GIS javascript API to pass lat/lng as input .
Rajasekhar
        wkid: 4326
MichaelOlkin
I've been interested for quite some time in being able to use url parameters to select & zoom to features by using the parameters in attribute queries.  It's disappointing that this basic function is still not included among the ArcGIS API for Javascript code samples.  I've gone ahead & developed my own code sample, which I've posted to ArcGIS.com here: http://www.arcgis.com/home/item.html?id=92ff586d7e934fde9ee62356592f8761
The sample that I posted uses two parameters to select a tax parcel.  Clicking a different parcel on the map revises the parameters.  The UrlToObject method in the Esri namespace is used to convert the url parameters into variables & the HTML5 Pushstate method is used for updating the parameters when a different parcel is clicked.
I hope that this sample is helpful.  All suggestions and comments are welcome.
Michael Olkin
GIS Administrator
Town of Amherst, MA
http://www.amherstma.gov/maps
KellyHutchins
Esri Notable Contributor
Nice sample Mike. This is a frequently asked question so we really should have a sample that shows how to do this in the help.
derekswingley1
The Specify WebMap via URL sample shows this.
MichaelOlkin
That's a good sample and it uses a URL parameter, but not to select a feature.
MichaelVolz
Esteemed Contributor
Does this page exist anymore?  If not, can anyone tell me where it has been moved to or at least some similar sample code?
KenBuja
MVP Esteemed Contributor
MichaelVolz
Ken:
According to your reply this sample URL is:
http://developers.arcgis.com/javascript/samples/ags_basic
Does I just add the extents the end of the URL for it to zoom in at start-up like this:
http://developers.arcgis.com/javascript/samples/ags_basic?Extent=-8427510.777,4867167.541,-8425000.4...
I got the extents by loading in an ESRI basemap which I thought would be the projection that would work with your sample, but it does not zoom to anything and just shows white space.
Am I using the wrong coordinate system in my test URL?
JordanBaumgardner
You get to specify the parameter format.
?x1=123.123&y1=123.123&...
?extent=123.13,123.12,123.12,123.12
What I think you might have missed is the JS code that reads it in.
//get the web map id from the url
urlObject
urlObject
.query = urlObject.query || {};
if(urlObject.query && urlObject.query.webmap){
    configOptions
.webmap = urlObject.query.webmap;
You need to read the params off the url/query string and the do something with the values.
