Urgent:Display the InfoWindow at the specified location
1016
04-10-2011 11:58 PM
Sophialim
anyone know how to use show(point, placement?) for infowindow cause in the API reference it has a code snippets:
map.infoWindow.show(location,esri.dijit.InfoWindow.ANCHOR_UPPERRIGHT);
the url is : http://help.arcgis.com/en/webapi/javascript/arcgis/help/jsapi_start.htm
the location is how to declare it? must we have var location and declare a coordinate to it or what?
cause what i want is Display the InfoWindow at the specified location, so that when drag the map it don't move
can show some examples??
HugoAhlenius
You have probably solved this already, but the location here is a esri.geometry.point, for instance.
