Upgrading to 4.28 - outFields contains invalid or missing fields
2177
12-12-2023 03:50 AM
michaelpoa
Unsupported query - using type: blob.
https://developers.arcgis.com/javascript/latest/api-reference/esri-layers-support-Field.html#type
Documentation:
Possible Values:"small-integer"|"integer"|"big-integer"|"single"|"double"|"long"|"string"|"date"|"date-only"|"time-only"|"timestamp-offset"|"oid"|"geometry"|"blob"|"raster"|"guid"|"global-id"|"xml"
2 Solutions
UndralBatsukh
You are getting this error likely because the field you are running the query on does not exist on the layer or the layer view. Try setting the FeatureLayer.outFields property to include the fields you want to work with.
UndralBatsukh
Hi there,
Ah yes this is a known issue at 4.28. This issue will be addressed in 4.29 and the fix is already in `next`. You can update your codepen to point to  <script src="https://js.arcgis.com/next/"></script> to check the fix.
Hope this helps,
UndralBatsukh
michaelpoa
Seems like there's an issue with the queryFeatures query with outFields and type 'blob'
I made a Codepen to reproduce it (check console.log). @UndralBatsukh
https://codepen.io/michaelk95/pen/PoVroJv
(Run 2 times to get the full error message)
Thanks
UndralBatsukh
Hi there,
Hope this helps,
