Upgrade to 3.1 - Seeing an extra button with dojoType=dijit.form.button
3659
7
09-04-2012 09:35 AM
KalaivaniNellaiappan
HI,
I have been upgrading my project from 1.5 to 3.1...
I am seeing an extra button pop-up by the sides of the existing button when i switch from 1.5 to 3.1?
When i go back to 1.5 it disappears...
Could you please help?
Vani
Hi , i have attached the screen shots...
with 1.5
[ATTACH=CONFIG]17493[/ATTACH]
with3.1
[ATTACH=CONFIG]17494[/ATTACH]
This is how i am seeing everywhere i have a dojo button...Could anyone please help?
Vani
derekswingley1
The easiest way to get help is to post code that reproduces the issue. Can you post a simple test page that shows the problem?
Here is the code and the screenshot of what i get from the code... The two long rectangle buttons which does nothing but could click on it appears when i switch from 1.5 to 3.1
Screen Shot...
[ATTACH=CONFIG]17506[/ATTACH]
Code
            <LoggedInTemplate>
                            <b>Required</b><br />
                            Title:<br />
                            <input type="text" id="comment-title" /><br />
                            Message:<br />
                            <textarea id="comment-message"></textarea><br /><br />
                            <b>Optional</b><br />
                            Select a point to relate this comment<br />
                            <button id="comment-select-on-map" dojoType="dijit.form.ToggleButton" iconClass="dijitCheckBoxIcon">Select on map</button><br /><br />
                            Select which layer(s) to relate this comment<br />
                            <div id="comments-addcomment-panel-threats">
                            </div>
                            <a id="select-all-threats" href="javascript:void(0);">Select All</a> &mdash; <a id="unselect-all-threats" href="javascript:void(0);">Unselect All</a><br /><br />
                            <input type="hidden" id="comment-latitude" />
                            <input type="hidden" id="comment-longitude" />
                            <span style="display: none;">Latitude:<br />
                            <br />
                            Longitude:<br />
                            <br /></span>
                            Type:<br />
                            <select id="comment-type"><%= this.commentTypes %></select><br />
                            <input type="checkbox" id="comment-betterdata" style="width: 20px;" /> <label for="comment-betterdata">Better Data Available</label><br /><br />
                            <button id="comment-add-comment-button" dojoType="dijit.form.Button">Submit Comment</button>
                        </LoggedInTemplate>
Vani
PaulFreeman
Did you ever find a solution to this?
I am getting the same when trying to upgrade from 1.4. I have narrowed it down to the changes between 2.0 and 2.1 but cannot find out what is causing the extra button. The code i am using is below.
this.button = new dijit.form.Button(
  label: 'Button'
__Rich_
That can't be all the code 🙂
Could you post a full sample?  (link to site or JSFiddle probably best, otherwise if not too big then posted here using code tags, or an attachment)
PaulFreeman
unfortunately the site is all intranet behind firewalls, the code is more than that, but even when i strip it back to the above i still get 2 buttons
dojo.provide("dcc.tool.basemap");
dojo.declare("dcc.tool.basemap", [dijit._Widget], {
    parentcontainer: "",
    load: function (node, map, file)
        this.parentcontainer = node;
        this.map = map;
        this.file= file;
        if (typeof this.contentPane == 'undefined')
            this.contentPane = new dijit.form.Button(
                label: ' Base Map '
            listnerArray.push(dojo.connect(this.contentPane.domNode, "onclick", function ()
                curbmPopup.containernode.OpenPopup();
                height = (((curbmPopup.containernode.countmaps / 3) ) * 75) + 10;
                dojo.byId("bsmapnode").style.height = height + "px";
                dojo.byId("bsmapnode").innerHTML = curbmPopup.containernode.BMHtml;
                // set highlighted base map
                try
                    dojo.query('#bm_' + curbmPopup.containernode.map.basemap.id)[0].style.border = "2px solid gray"
                catch (e)
        dojo.place(this.contentPane.domNode, node, "first");
        dojo.addClass(this.contentPane.domNode, "claro");
        if (typeof this.dropDown == 'undefined')
            this.dropDown = new dijit.TooltipDialog(
                onClose:  function(){ curLoadedPopup.isOpen = false;},
                content: '<span style="float:right;position :relative; cursor:pointer;" onclick="dijit.popup.close(curbmPopup);"><img src="' + 'image.gif" alt="X" title="Click to close"/></span><br/><center id="bsmapnode"></center>' ,
                style: "width:215px;"
            dojo.addClass(this.dropDown.domNode, "claro");
            this.dropDown.startup();
        this.dropDown.containernode = this;
        curbmPopup = this.dropDown;
        curLoadedPopup = this.dropDown;
        // load basemaps
        this.loadBaseMaps(environmentPath + "dcc_GIS_Config/App_Config/basemaps/"+ this.file, this);
    OpenPopup: function ()
        if (curLoadedPopup.isOpen){
           dijit.popup.close(curLoadedPopup);
        else
           if (typeof curLoadedPopup != 'undefined')
        this.popup = dijit.popup.open(
            popup: this.dropDown,
            around: this.contentPane.domNode,
            orient: {
                BL: 'TL'
        curLoadedPopup.isOpen= true;
    loadBaseMaps: function (jsonpath, node)
        dojo.xhrGet(
            url: jsonpath,
            load: function (response)
                node.BMHtml = "";
                node.countmaps = 0;
                dojo.forEach(response.basemaps, function (entry, index, array)
                    node.BMHtml += '<div id="bm_' + entry.id + '" style=" border:2px solid white; font-size:10px;width :54px;padding:3px; position:relative; float:left; cursor:pointer;" onclick="curbmPopup.containernode.setBaseMap(\'' + entry.URL + '\', \'' + entry.id + '\' , \'' + entry.name + '\' , \'' + entry.type + '\' , \'' + entry.copyright + '\', curbmPopup.containernode.map) ;">  <img width=55 src="' + entry.swatchURL + '"/><center>' + entry.name + '</center></div>';
                    node.countmaps++;
                try
                catch (e)
                response = null;
                return response;
            error: function (response, ioArgs)
                response = null;
                return response;
            handleAs: "json"
        //this.basemapConfig = this.map.dcc.getJson(jsonpath);
        //return this.basemapConfig;
setBaseMap: function (url, id, name, type, copyright, themap)
  if (typeof themap.basemap == 'undefined')
    this.basemapName = themap._layers[themap.layerIds[0]].id;
    themap.basemap = themap._layers[themap.layerIds[0]];
  if (this.basemapName != name) //if map has changed
   this.basemapId = id;
   this.basemapName = name;
   this.basemapType = type;
   this.url = url;
   this.copyright = copyright;
   // clear highlighted services
   try
    dojo.query('#bm_' + curbmPopup.containernode.map.basemap.id)[0].style.border = "2px solid white"
   catch (e)
   try
    themap.removeLayer(themap.basemap);
   catch (e)
   if (this.basemapType == "ArcGISDynamicMapServiceLayer")
    themap.basemap = new esri.layers.ArcGISDynamicMapServiceLayer(this.url, {
     transparent: true,
   else if (this.basemapType == "ArcGISTiledMapServiceLayer")
    themap.basemap = new esri.layers.ArcGISTiledMapServiceLayer(this.url, {
   themap.basemap = themap.addLayer(themap.basemap, 0);
   myLayers[0].Layer= themap.basemap;
   myLayers[0].Label = id;
   themap.basemap.url = url;
   themap.basemap.id = id;
   // themap.dcc.layers.basemap.id = id;
   dojo.byId("Copyright").innerHTML = this.copyright;
   //highlight mapservice
   try
   catch (e)
PaulFreeman
Problem solved, there was a link to the old CSS in an include file, updating this to 2.8 worked.
thanks for looking:)
