Upgrade Sample Viewer to 1.3: dojo tree breaks
1708
06-03-2010 12:48 PM
MostafaAsadi
When I switch the Sample Viewer to v1.3 the dojo tree in the Live Maps widget stops showing. Does anybody know why this is the case?
Thanks in advance!
nicogis
see all comments in http://resources.esri.com/arcgisserver/apis/javascript/arcgis/index.cfm?fa=codeGalleryDetails&script...
you also can see http://resources.geocortex.com/essentials/apis/javascript/samples/build/default/Instructions.html
(Update the API Version)
so you can run with version 1.6 and I advise use firebug so you can see future problem
MostafaAsadi
Yes, thanks. I have already read those comments on the ESRI page but none of them help. After debugging I get this message:
dojo.data.ItemFileReadStore: The json data provided by the creation arguments is malformed. Items within the list have identifier: [id]. Value collided: [Some City Landbase]
This worked fine with v1.2. Any other ideas?
nicogis
MostafaAsadi
Thanks. When you upgraded yours you didn't have any issues with the tree? I'm just wondering because I see everyone who has upgraded to 1.2+ has not mentioned anything about the tree breaking.
