union and then buffer not working
1630
11-30-2016 07:42 AM
by Anonymous User
Not applicable
Hi all,
I am trying to dissolve features using geometry serveice union then buffer the dissolve features 200' but I am getting errors. Any idea why?
Here is my code:
featureLayer.selectFeatures(selectQuery, FeatureLayer.SELECTION_NEW, function (targetGeometry) {
                          map.setExtent(graphicsUtils.graphicsExtent(featureLayer.getSelectedFeatures()), true);
                          targetGeometry = graphicsUtils.getGeometries(featureLayer.getSelectedFeatures());
                          console.log(targetGeometry);
                          geometryService.union(targetGeometry, function (geometry) {
                              geom = geometry;
                              featureLayer.clearSelection();
                              //Graphics to be shown on web map
                              var symbol = new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([180, 50, 250]), 4);
                              graphic = new Graphic(geometry, symbol);
                              map.graphics.add(graphic);
                              //feature set to feed the geoprocessing service
                              var features = [];
                              FeaturesetGraphs = new FeatureSet();
                              FeaturesetGraphs.features = features;
                              features.push(graphic);
                              //Make a buffer from the features
                              //setup the buffer parameters
                              var params = new BufferParameters();
                              params.distances = [200];
                              params.outSpatialReference = map.spatialReference;
                              params.unit = geometryService.UNIT_FOOT;
                              params.geometries = [geometry];
                              geometryService.buffer(params, function (bufferedGeometries) {
                                      var symbol2 = new SimpleFillSymbol(SimpleFillSymbol.STYLE_SOLID, new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([0, 0, 0]), 4), new Color([247, 242, 89, 0.6]));
                                      var graphic2 = new Graphic(bufferedGeometries, symbol2);
                                      map.graphics.add(graphic2);
                              //Area calculations for the project definition
                              var areasAndLengthParams = new AreasAndLengthsParameters();
                              areasAndLengthParams.areaUnit = GeometryService.UNIT_ACRES;
                              areasAndLengthParams.calculationType = "geodesic";
                              geometryService.simplify([geometry], function (simplifiedGeometries) {
                                  areasAndLengthParams.polygons = simplifiedGeometries;
                                  geometryService.areasAndLengths(areasAndLengthParams);
                          }, function (err) {
                              console.log(err);
RobertScheitlin__GISP
Alex,
  I would try simplifying the geometry before you buffer it (just like you are doing before you do the area calculations).
Alex,
by Anonymous User
Not applicable
That was it thanks Robert!
