Understanding Impact of removal of Python 2.x from ArcGIS server 10.9.1
781
02-04-2025 08:17 PM
SaurabhDudhe
Hello,
We understood that :
(a) 'ArcMap Runtime' uses Python 2.x within 'ArcGIS Server 10.9.1'.
(b) We also understand there is a way to disable 'ArcMap Runtime' as per - https://enterprise.arcgis.com/en/server/10.9.1/administer/linux/disable-arcmap-runtime.htm
- we are using 'ArcGIS Maps SDK' to consume features from 'ArcGIS Server 10.9.1'.
- We are using 'ArcMap' to publish layer services into 'ArcGIS Server 10.9.1.
We have below queries :
(1)  Will it impact us if we disable 'ArcMap Runtime' as per (b) while consuming already existing/configured services/layers in 'ArcGIS Server 10.9.1' using 'ArcGIS Maps SDK' from our web application ?
(2) In this setup, can I just replace 'ArcMap' with 'ArcGIS Pro' to publish services/layers into 'ArcGIS Server 10.9.1' after disabling 'ArcMap Runtime' as per (b)  ?
Our need is -
We want to continue using 'ArcGIS Server 10.9.1' for its services from client App (using 'ArcGIS Map SDK'), after disabling 'ArcMap runtime' in the server. This is just to ensure 'Python 2.x' is not present and things are still working after layers are published.
Thanks in advance.
Sage_Wall
Hi @SaurabhDudhe , I think you will likely get a better answer from the Enterprise community, you probably want to post over here: https://community.esri.com/t5/arcgis-enterprise-questions/bd-p/arcgis-enterprise-questions
