Uncaught TypeError: Photos.setLabelingInfo is not a function
1874
04-30-2017 07:10 AM
IsaacBoates
I am trying to create a web map with javascript, and I keep getting this error.  I have pretty much copy and pasted the code from this page: Labeling features on the client | ArcGIS API for JavaScript 3.20
This is the code (I am clicking on the "code" button in the post interface but it refuses to format properly):
var map; <!-- Import der vordefinierten Module für die Variable "Map" -->
require([
"esri/symbols/SimpleLineSymbol",
"esri/symbols/SimpleFillSymbol",
"esri/symbols/TextSymbol",
"esri/renderers/SimpleRenderer",
"esri/layers/LabelClass",
"esri/Color",
"esri/geometry/Extent",
"esri/map",
"esri/dijit/BasemapToggle",
"esri/layers/ArcGISDynamicMapServiceLayer",
"esri/layers/FeatureLayer",
"esri/layers/RasterFunction",
"esri/layers/ImageParameters",
"esri/layers/ArcGISTiledMapServiceLayer",
"esri/dijit/Popup",
"esri/dijit/PopupTemplate",
"dojo/dom-construct",
"dojo/on",
"esri/InfoTemplate",
"dojo/dom",
"dojo/query",
"dojo/domReady!",
"esri/dijit/Legend",
"dojo/_base/array",
"dojo/parser",
"dijit/form/HorizontalSlider",
"esri/dijit/Scalebar"],
function(SimpleLineSymbol,
SimpleFillSymbol,
TextSymbol,
SimpleRenderer,
LabelClass,
Color,
Extent,
Map,
BasemapToggle,
ArcGISDynamicMapServiceLayer,
FeatureLayer,
RasterFunction,
ImageParameters,
ArcGISTiledMapServiceLayer,
Popup,
PopupTemplate,
DomConstruct,
on,
InfoTemplate,
dom,
query,
ready,
Legend,
arrayUtils,
parser,
HorizontalSlider,
Scalebar)
var extent = new Extent({"xmin":2054005.395500005 , "ymin":6188618.186554961, "xmax":2079286.521715342, "ymax":6203773.949341377,"spatialReference": {"wkid": 3857}});
var popup = Popup({ <!-- Definition Popup -->
titleInBody: false
},DomConstruct.create("div"));
map = new Map("mapDiv", {
"extent": extent,
basemap:"topo",
infoWindow: popup, <!-- Füllen des Info Windows -->
showLabels: true
var Scalebar = new Scalebar({
map: map,
scalebarUnit: "dual",
attachTo: "bottom-left"
document.getElementsByClassName("scalebar_bottom-left esriScalebar")[0].style.bottom= "60px";
document.getElementsByClassName("scalebar_bottom-left esriScalebar")[0].style.left= "25px";
document.getElementsByClassName("esriScalebarLabel")[0].style.color ="black";
document.getElementsByClassName("esriScalebarLabel")[1].style.color ="black";
document.getElementsByClassName("esriScalebarLineLabel")[0].style.color ="black";
document.getElementsByClassName("esriScalebarLineLabel")[1].style.color ="black";
document.getElementsByClassName("esriScalebarLine")[1].style.borderColor="black"
document.getElementsByClassName("esriScalebarMetricLine")[0].style.borderColor="black"
document.getElementsByClassName("esriScalebarLabel")[0].style.color = "black";
document.getElementsByClassName("esriScalebarLabel")[1].style.color = "black";
var toggle = new BasemapToggle({
map: map,
basemap: "satellite"
}, "BasemapToggle");
toggle.startup();
<!-- web services begin here -->
var Photos = new FeatureLayer("https://www.imm.hs-karlsruhe.de/devsrv/rest/services/Gr2_Slvk2017/Gr2_P_VP_2_Photos/MapServer/0", {
outFields: ["*"],
visible: true
var photosColor = new Color("#ffffff");
var photosLine = new SimpleLineSymbol("solid", photosColor, 1.5);
var photosSymbol = new SimpleFillSymbol("solid", photosLine, null);
var photosRenderer = new SimpleRenderer(photosSymbol);
var json = {
"labelExpressionInfo": {"value": "{azimuth}"}
var photosLabel = new TextSymbol().setColor(photosColor);
photosLabel.font.setSize("14pt");
photosLabel.font.setFamily("arial");
var labelClass = new LabelClass(json);
labelClass.symbol = photosLabel; // symbol also can be set in LabelClass' json
Photos.setLabelingInfo([ labelClass ]);
map.addLayer(Photos);
KenBuja
MVP Esteemed Contributor
This code seems to be working. I substituted a sample service in place of yours.
<!DOCTYPE html>
<html>
<head>
  <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
  <meta name="viewport" content="initial-scale=1, maximum-scale=1, user-scalable=no">
  <title>Labeling features client-side</title>
  <link rel="stylesheet" href="https://js.arcgis.com/3.20/esri/css/esri.css">
  <style>
    html, body, #mapDiv {
      height: 100%;
      width: 100%;
      margin: 0;
      padding: 0;
  </style>
  <script src="https://js.arcgis.com/3.20/"></script>
  <script>
    var map;
    require([
    "esri/Color",
    "esri/map",
    "esri/dijit/Popup",
    "dojo/on",
    "dojo/dom",
    "dojo/query",
    "dojo/_base/array",
    "dojo/parser",
    "esri/dijit/Scalebar",
    "dojo/domReady!"],
    function (SimpleLineSymbol,
    SimpleFillSymbol,
    TextSymbol,
    SimpleRenderer,
    LabelClass,
    Color,
    Extent,
    Map,
    BasemapToggle,
    FeatureLayer,
    RasterFunction,
    ImageParameters,
    Popup,
    PopupTemplate,
    DomConstruct,
    on,
    InfoTemplate,
    dom,
    query,
    Legend,
    arrayUtils,
    parser,
    HorizontalSlider,
    Scalebar) {
      var extent = new Extent({ "xmin": 1054005.395500005, "ymin": 6188618.186554961, "xmax": 2079286.521715342, "ymax": 6203773.949341377, "spatialReference": { "wkid": 3857 } });
      var popup = Popup({
        titleInBody: false
      }, DomConstruct.create("div"));
        extent: extent,
        basemap: "topo",
        infoWindow: popup,
        showLabels: true
        map: map,
      document.getElementsByClassName("scalebar_bottom-left esriScalebar")[0].style.bottom = "60px";
      document.getElementsByClassName("scalebar_bottom-left esriScalebar")[0].style.left = "25px";
      document.getElementsByClassName("esriScalebarLineLabel")[0].style.color = "black";
      document.getElementsByClassName("esriScalebarLineLabel")[1].style.color = "black";
      document.getElementsByClassName("esriScalebarLine")[1].style.borderColor = "black"
      document.getElementsByClassName("esriScalebarMetricLine")[0].style.borderColor = "black"
        map: map,
      toggle.startup();
      var Photos = new FeatureLayer("https://sampleserver6.arcgisonline.com/arcgis/rest/services/Wildfire/FeatureServer/0", {
        outFields: ["*"],
        visible: true
      var photosColor = new Color("#000000");
      var json = {
        "labelExpressionInfo": { "value": "{created_user}" }
      Photos.setLabelingInfo([labelClass]);
  </script>
</head>
<body>
  <div id="mapDiv"></div>
</body>
</html>
IsaacBoates
Hi Ken, thank you for your response.  I changed my web service from MapServer to FeatureServer, but I don't know if that made a difference or not.  The real problem was that my script was importing arcgis javascript api 3.9 instead of 3.20.
