Uncaught TypeError: Converting circular structure to JSON for printing
8207
9
05-12-2015 02:47 PM
jamesa
I want to print a map after buffer is completed and show all the highlighted parcels using print widget but I got error message:
The main code for buffer from here:https://community.esri.com/thread/121140?q=buffer%20results#463851
and use print widget from sample here: https://developers.arcgis.com/javascript/jssamples/widget_print_esri_request.html
Besides that, I also found this thread if you have graphics:
https://community.esri.com/thread/69239
with this solution
var graphic = new esri.Graphic(result.feature.toJson());
But how do you apply it with FeatureLayer or geometry?
Please share you options.
Thank you.
RobertScheitlin__GISP
James,
  Sure try this one:
James,
   Can you zip up and attach your whole code?
jamesa
All my map services are secured services and not open to public.  When I first click on print button without any search,  I able to print a map . But after performed selected search with buffer or without buffer and text search with buffer will got error message,  For text search part, I added  this line " var graphic = new esri.Graphic(result.feature.toJson());" , so able to print.
I am not sure how to upload the zip file here.  So put the codes together below:
Can you help me take a look and  try to use your own map services, proxy server, &  print task to see if you got those error message?
Thank you for your time.
<!DOCTYPE html>
    <html>
    <head>
      <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
      <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
      <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
      <title>Buffer</title>
      <link rel="stylesheet" href="http://js.arcgis.com/3.13/dijit/themes/claro/claro.css">
      <link rel="stylesheet" href="http://js.arcgis.com/3.13/esri/css/esri.css">
      <style>
        html,
        body {
          height: 100%;
          width: 100%;
          margin: 0;
          padding: 0;
          overflow: hidden;
        #leftPane {
          color: #000;
          width: 250px;
          padding-bottom: 15px;
        #map {
          padding: 0;
        .details {
          font-size: 14px;
          font-weight: 600;
          padding-bottom: 20px;
        button {
          margin: 2px;
          cursor: pointer;
      </style>
      <script src="http://js.arcgis.com/3.13/"></script>
      <script>
        require([
              "esri/map",
              "esri/config", "esri/layers/ArcGISDynamicMapServiceLayer",
              "esri/layers/FeatureLayer", "esri/dijit/Print", "esri/tasks/PrintTemplate", "esri/request",
   "esri/tasks/FindTask",
   "esri/tasks/FindParameters",
              "esri/symbols/SimpleFillSymbol",
   "esri/symbols/SimpleLineSymbol",
              "dojo/request/iframe",
   "esri/toolbars/draw",
   "esri/tasks/QueryTask",
              "esri/tasks/query",
              "esri/graphic",
              "esri/graphicsUtils",
   "esri/geometry/Geometry",
   "esri/geometry/Extent",
              "esri/SpatialReference",
              "esri/geometry/geometryEngineAsync",
              "esri/tasks/GeometryService",
              "esri/Color",
              "dojo/on",
              "dojo/dom",
              "dijit/registry",
              "dojo/_base/array",
              "dojox/grid/DataGrid",
              "dojo/data/ItemFileReadStore",
              "dijit/form/Button",
              "dojo/parser",
   "dojo/store/Memory",
              "dojo/data/ItemFileWriteStore",
              "dgrid/OnDemandGrid",
              "dojox/grid/EnhancedGrid",
              "dojox/grid/enhanced/plugins/exporter/CSVWriter",
              "dojox/grid/enhanced/plugins/Printer",
              "dijit/layout/BorderContainer",
              "dijit/layout/ContentPane",
              "dojo/domReady!"
        ], function (
          Map, esriConfig, ArcGISDynamicMapServiceLayer, FeatureLayer, Print, PrintTemplate, esriRequest, FindTask, FindParameters, SimpleFillSymbol, SimpleLineSymbol, iframe, Draw, QueryTask, Query,
          Graphic, graphicsUtils, Geometry, Extent, SpatialReference, geometryEngineAsync, GeometryService,
          Color, on, dom, registry, arrayUtils, DataGrid, ItemFileReadStore, Button, parser, Memory,
          ItemFileWriteStore, Grid, EnhancedGrid, CSVWriter, Printer) {
          var map, center, zoom;
          var graphic;
          var bufferGra;
          var symbol, sfs, symbolP;
          var bufferGraF;
          var selectionToolbar;
          parser.parse();
         var printUrl = "http://servername/ags/rest/services/PrintCustom/ExportWebMapSecure3/GPServer/Export%20Web%20Map";
  var initExtent = new esri.geometry.Extent({"xmin":,"ymin":,"xmax":,"ymax":,"spatialReference":{"wkid":}});
   esri.config.defaults.io.proxyUrl = "http://servername/proxy/proxy.ashx";
       esri.config.defaults.io.alwaysUseProxy = true;
          map = new Map("map",{
   extent:initExtent
          map.on("load", initSelectToolbar);
   on(dom.byId("selectFieldsButton"), "click", function () {
          selectionToolbar.activate(Draw.EXTENT);
   var parcelsURL1 = "http://servername/ags/rest/services/Intranet/MapServer";
  map.addLayer(new ArcGISDynamicMapServiceLayer(parcelsURL1,
   { opacity: .95 }));
  // get print templates from the export web map task ----------------------
        var printInfo = esriRequest({
          "url": printUrl,
          "content": { "f": "json" }
        printInfo.then(handlePrintInfo, handleError);
        function handlePrintInfo(resp) {
          var layoutTemplate, templateNames, mapOnlyIndex, templates;
          layoutTemplate = arrayUtils.filter(resp.parameters, function(param, idx) {
            return param.name === "Layout_Template";
          if ( layoutTemplate.length == 0 ) {
            console.log("print service parameters name for templates must be \"Layout_Template\"");
            return;
          templateNames = layoutTemplate[0].choiceList;
          // remove the MAP_ONLY template then add it to the end of the list of templates
          mapOnlyIndex = arrayUtils.indexOf(templateNames, "MAP_ONLY");
          if ( mapOnlyIndex > -1 ) {
            var mapOnly = templateNames.splice(mapOnlyIndex, mapOnlyIndex + 1)[0];
            templateNames.push(mapOnly);
          // create a print template for each choice
          templates = arrayUtils.map(templateNames, function(ch) {
            var plate = new PrintTemplate();
            plate.layout = plate.label = ch;
            plate.format = "PDF";
            plate.layoutOptions = {
              "authorText": "Made by:  Esri's JS API Team",
              "copyrightText": "<copyright info here>",
              "legendLayers": [],
              "titleText": "Pool Permits",
              "scalebarUnit": "Miles"
            return plate;
          // create the print dijit
          printer = new Print({
            "map": map,
            "templates": templates,
            url: printUrl
          }, dom.byId("print_button"));
          printer.startup();
        function handleError(err) {
          console.log("Something broke: ", err);
//End Print Task --------------------------------------------
          registry.byId("search").on("click", doFind);
          registry.byId("applyBufferPF").on("click", doBuffer);
          registry.byId("applyBufferPSel").on("click", applyBufferPSel);
          registry.byId("clearParcelGrid").on("click", clearParcelGrid);
//set symbol --------------
         symbol = new SimpleFillSymbol(SimpleFillSymbol.STYLE_NULL, new SimpleLineSymbol(SimpleFillSymbol.STYLE_SOLID, new Color([100, 100, 100]), 2), new Color([0, 0, 255, 0.20]));  //Gray line
  sfs = new SimpleFillSymbol(
            new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([98, 194, 204]), 2),
            new Color([98, 194, 204, 0.3])
          ); // blue solid
  symbolP = new SimpleFillSymbol(SimpleFillSymbol.STYLE_NONE,
  new SimpleLineSymbol(SimpleLineSymbol.STYLE_CROSS, new Color([98, 194, 204]), 2),
  new Color([98, 194, 204, 0.5])); // symbol for buffer result ring - black solid
//Find Parcel -----------
          //Create Find Task using the URL of the map service to search
          findTask = new FindTask("http://servername/ags/rest/services/Intranet/MapServer/");
   var parcelUrl = "http://servername/ags/rest/services/Intranet/MapServer/12";
          var featureLayerParcel = new FeatureLayer(parcelUrl, {
            mode: FeatureLayer.MODE_SELECTION,
            visible: true,
            outFields: ["*"]
          featureLayerParcel.setSelectionSymbol(symbolP);
          map.addLayer(featureLayerParcel);
  map.on("load", function () {
              //Create the find parameters
              findParams = new FindParameters();
              findParams.returnGeometry = true;
              findParams.layerIds = [12];
              findParams.searchFields = ["parcelid"];
              findParams.outSpatialReference = map.spatialReference;
          function doFind() {
   clearParcelGrid();
              //Set the search text to the value in the box
              findParams.searchText = dom.byId("Number").value;
              findTask.execute(findParams, function (results) {
      showResults(results);
            function showResults(results) {
              //This function works with an array of FindResult that the task returns
              map.graphics.clear();
              //create array of attributes
              var items = arrayUtils.map(results, function (result) {
                  //var graphic = result.feature;
   graphic.setSymbol(symbol);
                  map.graphics.add(graphic);
                  return result.feature.attributes;
              //Create data object to be used in store
              var data = {
                  identifier: "parcelid", //This field needs to have unique values
                  label: "parcelid", //Name field for display. Not pertinent to a grid but may be used elsewhere.
                  items: items
              //Create data store and bind to grid.
              var store = new ItemFileReadStore({
                  data: data
              var gridP = registry.byId("gridP");
              gridP.setStore(store);
  var extent = esri.graphicsExtent(map.graphics.graphics);
       map.setExtent(extent, true);
   bufferGraF = map.graphics.graphics; // send graphic to buffer
    function doBuffer(results) {
  var graphics = bufferGraF;
  var selectedGeoms = graphicsUtils.getGeometries(graphics);
            var symbol = new SimpleFillSymbol(SimpleFillSymbol.STYLE_SOLID, SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID,
                new Color([0, 0, 255, 0.65]), 2
              new Color([0, 0, 255, 0.35])
            geometryEngineAsync.buffer(selectedGeoms, [100], GeometryService.UNIT_FOOT, true).then(
              function (geoms) {
                arrayUtils.forEach(geoms, function (geometry) {
                  map.graphics.add(new Graphic(geometry, symbol));
                bufferGra = geoms;
                intersectParcelsF(); // combine buffer & intersect parcels
    //query Parcel
          function intersectParcelsF() {
            geometryEngineAsync.union(bufferGra).then(
              function (union) {
                var queryNew = new Query();
                queryNew.outFields = ["parcelid"];
                queryNew.spatialRelationship = Query.SPATIAL_REL_INTERSECTS;
                queryNew.geometry = union;
                queryNew.returnGeometry = true;
                featureLayerParcel.selectFeatures(queryNew, FeatureLayer.SELECTION_ADD, function (features, selectionMethod) {
                  var items = dojo.map(features, function (feature) {
                    return feature.attributes;
                  var data = {
                    items: items
                    data: data
                  var grid = registry.byId("parcelGrid");
                  grid.setStore(store);
                  symbolInt = new SimpleFillSymbol(SimpleFillSymbol.STYLE_NULL, new SimpleLineSymbol(SimpleFillSymbol.STYLE_NULL, new Color([100, 100, 100]), 2), new Color([0, 0, 255, 0.20]));  //Gray line
                  arrayUtils.forEach(features, function (feature) {
                    graphic = new Graphic(feature.geometry, symbolInt);
     //End Find Parcel ---------------
//Select parcel -------------------------
  function initSelectToolbar (event) {
   selectionToolbar = new Draw(event.map);
    var query2 = new esri.tasks.Query();
   on(selectionToolbar, "DrawEnd", function (geometry) {
  selectionToolbar.deactivate();
  query2.geometry = geometry;
  featureLayerP.selectFeatures(query2, esri.layers.FeatureLayer.SELECTION_NEW, function(features, selectionMethod) {
  var items30 = dojo.map(features, function(feature) {
  var data30 = {
  items: items30
  var store30 = new dojo.data.ItemFileReadStore({
  data: data30
  var selGrid = registry.byId("gridP");
  selGrid.setStore(store30);
  selGrid.resize();
  map.setExtent(graphicsUtils.graphicsExtent(featureLayerP.getSelectedFeatures()), true);
         var featureLayerUrl = "http://servername/ags/rest/services/Intranet/MapServer/12";
         var featureLayerP = new esri.layers.FeatureLayer(featureLayerUrl, {
             mode: esri.layers.FeatureLayer.MODE_SELECTION,
             visible: true,
  outFields: ["*"]
  featureLayerP.setSelectionSymbol(symbolP);
         map.addLayer(featureLayerP);
//Select Parcel
    function intersectParcelsSel() {
              function (union) {
                featureLayerP.selectFeatures(queryNew, FeatureLayer.SELECTION_ADD, function (features, selectionMethod) {
                  var data = {
                    items: items
                    data: data
      function applyBufferPSel() {
  alert(featureLayerP.graphics.length);
           //Select Parcel
  var graphicsSel = featureLayerP.graphics;
            var selectedGeomsSel = graphicsUtils.getGeometries(graphicsSel);
            geometryEngineAsync.buffer(selectedGeomsSel, [100], GeometryService.UNIT_FOOT, true).then(
              function (geoms) {
                bufferGra = geoms;
                intersectParcelsSel(); // combine buffer & intersect parcels
//End Select Parcel #2 -------------------------------------------------------------------------------------------------
          function clearParcelGrid() {
            var newStore = new ItemFileReadStore({
              data: {
                idenitifer: "",
                items: []
            var grid = registry.byId("gridP");
            grid.setStore(newStore);
  var gridParcel = registry.byId("parcelGrid");
            gridParcel.setStore(newStore);
  featureLayerParcel.clearSelection();
  featureLayerP.clearSelection();
      </script>
      <body class="claro">
        <div data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline'" style="width:100%;height:100%;margin:0;">
          <div data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'top'" style="height:200px;" title="Search">
            Search by Parcel #:
            <input type="text" id="Number" size="60"/>
            <button id="search" data-dojo-type="dijit.form.Button" type="button" data-dojo-attach-point="button">Search</button>
  <button id="applyBufferPF" data-dojo-type="dijit/form/Button" type="button" data-dojo-attach-point="button">Buffer</button>
  <br>
            <button id="selectFieldsButton" data-dojo-type="dijit/form/Button">Select Fields</button>
            <button id="applyBufferPSel" data-dojo-type="dijit/form/Button" type="button" data-dojo-attach-point="button">Buffer by Selected Parcel</button>
    <button id="clearParcelGrid" data-dojo-type="dijit/form/Button" type="button" data-dojo-attach-point="button">Clear</button>
           <div id="print_button"></div>
            <table data-dojo-type="dojox/grid/EnhancedGrid" data-dojo-id="gridP" id="gridP" data-dojo-props="rowsPerPage:'5', rowSelector:'20px', plugins:{printer: true, exporter: true}">
              <thead>
    <tr>
   <th field="parcelid">Parcel ID</th>
                </tr>
              </thead>
            </table>
  <br>
            <table data-dojo-type="dojox/grid/EnhancedGrid" data-dojo-id="parcelGrid" id="parcelGrid" data-dojo-props="rowsPerPage:'5', rowSelector:'20px', plugins:{printer: true, exporter: true}">
                <thead>
                  <tr>
                  </tr>
                </thead>
           </table>
          </div>
          <div id="map" data-dojo-props="region:'center'" data-dojo-type="dijit/layout/ContentPane" style="border:1px solid #000;"></div>
        </div>
      </body>
James,
  I switched all your use of FeatureLayer to instead use GraphicsLayer. This allowed be to get past the Cyclic error.
jamesa
Robert,
Thank you for your attachment file.  Now I only got same error message for printing when try to do a text search with buffer.  Do I also need to use GraphicsLayer inside showResults function instead of map.graphics.add(graphic)?
Thank you again.
James,
  So it turns out the real issue was with the main parcel that was selected before the buffer needed to be removed to prevent a duplicate of itself from being present in the print.  I have reverted much of my previous changes and tested this pretty thoroughly. I made some other changes too.
jamesa
I comment out this line //findParams.contains = false; then able to run a text search and everything working great! Is there possible to make buffer ring on top of parcels? Didn't find it under API reference for GraphicsLayer.
Thank you Robert so much for your time.
James,
  Sure try this one:
jamesa
Thank you so much.  It works. Can I ask you last questions before I mark this thread or I need to open a new thread.  Not sure. I try to add some functions inside showResults() to can zoom to selected parcels on datagrid record, mouseover to highlight parcel or mouseout.  I didn't find any error message when adding those functions.  Thanks again.
gridP.on("rowclick", onRowClickHandler);
gridP.on("mouseover", onMouseOverHandler);
gridP.on("mouseout", onMouseOutHandler);
function onRowClickHandler(evt) {
          var clickedTaxLotId = evt.grid.getItem(evt.rowIndex).parcelid;
          var selectedTaxLot = arrayUtils.filter(parcelGL.graphics, function (graphic) {
            return ((graphic.attributes) && graphic.attributes.parcelid === clickedTaxLotId);
          if ( selectedTaxLot.length ) {
            map.setExtent(selectedTaxLot[0].geometry.getExtent(), true);
  function onMouseOverHandler(evt){
    if(evt.rowIndex == -1){
  return;
  var rowId = grid.getItem(evt.rowIndex).parcelid;
  arrayUtils.some(parcelGL.graphics,function(graphic){
    if ((graphic.attributes) && graphic.attributes.parcelid === rowId) {
    graphic.setSymbol(sfs);
  return true;
  function onMouseOutHandler(evt){
  if (graphic.symbol == sfs) {
  graphic.setSymbol(symbolP);
  return true;
James,
   You definitely need to close this thread by marking it as answered. Your problem is
Don't add those "on" event in the showResults() function just add them right after your other event handlers right after:
registry.byId("clearBuffer").on("click", clearBuffer);
