UNABLE TO ZOOM TO POINT FEATURE
3177
10-17-2016 05:03 AM
bharathreddy
Here is my code i am able to add graphics but unable to zoom please help
<!DOCTYPE html>
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8">
<meta http-equiv="X-UA-Compatible" content="IE=7, IE=9, IE=10">
<!--The viewport meta tag is used to improve the presentation and behavior of the samples
on iOS devices-->
<meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
<title>Identify with Popup</title>
<link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.5/js/esri/css/esri.css">
<style>
html, body, #mapDiv {
height:100%;
width:100%;
margin:0;
padding:0;
</style>
<script src="http://serverapi.arcgisonline.com/jsapi/arcgis/3.5/"></script>
<script type="text/javascript">
dojo.require("esri.map");
dojo.require("esri.tasks.query");
var map, queryTask, query;
var symbol, infoTemplate;
var totalExtent;
function init() {
map = new esri.Map("mapDiv", {
center: [19.46, 50.382],
zoom: 4
dynamicmap = new esri.layers.ArcGISDynamicMapServiceLayer("http://localhost:6080/arcgis/rest/services/edit/MapServer");
map.addLayer(dynamicmap);
queryTask = new esri.tasks.QueryTask("http://localhost:6080/arcgis/rest/services/edit/MapServer/20");
// //initialize query
query = new esri.tasks.Query();
query.returnGeometry = true;
query.outFields = ["LTP_ID ", "OBJECTID "];
//create symbol for selected features
symbol = new esri.symbol.SimpleMarkerSymbol();
symbol.setStyle(esri.symbol.SimpleMarkerSymbol.STYLE_SQUARE);
symbol.setSize(10);
symbol.setColor(new esri.Color([255, 255, 0, 0.5]));
function executeQueryTask(sTownID) {
// debugger;
//set query based on what user typed in for population;
//query.where = "POP04 > " + population;
// var sTownID = $get('population').value ;
query.where = "LTP_ID ='" + sTownID + "'";
//execute query
queryTask.execute(query, showResults);
// var zm = queryTask.execute(query, showResults);
// map.centerAndZoom(zm, 2);
function showResults(featureSet) {
debugger;
//remove all graphics on the maps graphics layer
map.graphics.clear();
//Performance enhancer - assign featureSet array to a single variable.
var resultFeatures = featureSet.features;
//Loop through each feature returned
for (var i = 0, il = resultFeatures.length; i < il; i++) {
//Get the current feature from the featureSet.
//Feature is a graphic
var graphic = resultFeatures;
//graphic.setSymbol(symbol);
//Set the infoTemplate.
//graphic.setInfoTemplate(infoTemplate);
//Add graphic to the map graphics layer.
map.graphics.add(graphic);
map.setExtent(graphic.geometry.getExtent(), true);
dojo.ready(init);
</script>
</head>
<body>
<br/>
Enter Value : <input type="text" id="pop" />
<input type="button" value="Get Details" onclick="executeQueryTask(dojo.byId('pop').value);" />
<div id="mapDiv" style="width:1000px; height:800px; border:1px solid #000;"></div>
</body>
</html>
RobertScheitlin__GISP
Bharath,
   A Point geometry does not have an extent, so this code does nothing
Something like this would work better:
if (graphic.geometry.type === 'point') {
    var mz = map.getMaxZoom() ;
    if (mz > -1) {
        map.centerAndZoom(graphic.geometry, mz - 2);
    } else {
        map.centerAndZoom(graphic.geometry, 0.25);
} else {
    map.setExtent(graphic.geometry.getExtent());
Bharath,
    if (mz > -1) {
    } else {
} else {
bharathreddy
the above didnt work for me
bharathreddy
thanks Robert,
it worked for me with few modifications
Bharath,
Don't forget to mark this question as answered by clicking on the "Correct Answer" link on the reply that answered your question.
