Unable to show Map Navigation Toolbar Icons
2156
04-01-2017 05:55 AM
AlbertoPinilla
Does anybody know why icons in this example from arcgis api javascript page don't show?
Map navigation tools | ArcGIS API for JavaScript 3.20
Is it an issue about links with dependencies?
How can I reference dijit icons on my application?
Thanks in advance
thejuskambi
I think it just the sandbox which is failing to show the images. If you look at the Live version its working.
If you look at the sample, you will see that all the icons are setup through css and the iconClass are defined for each button in HTML like below.
<div data-dojo-type="dijit/form/Button" id="zoomin"
    data-dojo-props="iconClass:'zoominIcon'">Zoom In</div>‍‍‍
If you want to change the icon, you can define you own Icon style css and update the iconClass in the properties.
AlbertoPinilla
You're right, Thejus. I didn´t notice the live example does reference the icons in the right way. I had created a html document with the same code and it didn't import the icons either. It is a problem whith the relative link to the current location of the example page: "Navigation toolbar ". I don't know why, but I had imagined the icons woud be taken from the dojo toolkit and that got me some confusion.
Thanks, anyway.
RobertScheitlin__GISP
I have reported the 404 error to esri using their page not found "Report a Problem" link.
