Unable to print Bing basemaps
2259
01-18-2013 06:39 AM
DerekWicks1
Using the Print widget I am unable to print any of the Bing basemaps. All of the regular Esri basemaps print fine but when I try to print a map with a Bing basemap turned on I get the following error:
Error executing tool.: Layer "layer0": Unable to connect to Microsoft Bing service. Authentication failed. Failed to execute (Export Web Map). Failed to execute (Export Web Map Task).
[ATTACH=CONFIG]20843[/ATTACH]
I am using version 3.3 of the API and Server 10.1 SP1. Server Manager shows I have the Bing Maps extension enabled and I have entered the Bing key when adding the basemaps to the basemap gallery. I am able to print Bing basemaps using the Esri sample server leading me to believe that there is some sort of setting or parameter I'm missing in my PrintingTools service.
ShreyasVakil
Check if your ArcGIS Server machine has internet access to access the bing map service.
DerekWicks1
Don't think this is the problem, the machine has internet access and is able to ping www.bing.com.
MattNicol
Print requests do not include the Bing Maps key for some reason.  If you're using a proxy to handle requests, you can add the Bing Maps key through code, and the request will authorize.
Look for something like this in your request:
[{"id":"layer2","visibility":true,"type":"BingMapsroad","culture":"en-US","opacity":1}
And change it to this:
[{"id":"layer2","visibility":true,"token","<YOURBINGMAPSKEY>","type":"BingMapsroad","culture":"en-US","opacity":1}
