Unable to get form to validate when I click submit button.
8058
7
04-29-2015 01:49 PM
ChrisSergent
I have three  fields in a form call feedbackModal. They are all required and mark withed required, but when I click submit, I receive the following error: Uncaught TypeError: Cannot read property '0' of null for the following lines of code:
// submit or cancel request and hide modal
        query("#feedbackModal .btn").on("click", function (e) { // e is defined but never used.
            // NOTE: this is not implemented in sample app
            if (document.getElementById("#feedbackModal")[0].checkValidity()) {
                query("#feedbackModal").modal("hide");
            else {
                //show errors
                return false;
and this one:
on(dom.byId("btnFeedback"), "click", function () {
        sendEmail();
    function sendEmail() {
            var link = "mailto:" + document.getElementById("eMail").value
            + "&subject=" + escape(document.getElementById('subject').value)
            + "&body=" + escape(document.getElementById('comment').value)
        else {
            //show errors
            return false;
            alert("All fields are required!");
KenBuja
MVP Esteemed Contributor
This message means that the object 'document.getElementById("#feedbackModal")' is null. Should you use "feedbackModal" instead of "#feedbackModal"?
ChrisSergent
I actually don't think it will. I realized that I am trying to use jQuery syntax. Tom Wayson​ said that I should try dojo instead: https://dojotoolkit.org/documentation/tutorials/1.10/validation/ I will update the post if it works or does not.
ChrisSergent
I have this block of code and I still get: Uncaught TypeError: Cannot read property 'validate' of undefined
        sendEmail();
    function sendEmail(ev) {
        if (this.validate()) {
            return confirm('Form is valid, press OK to submit');
        } else {
            alert('Form contains invalid data.  Please correct first');
            return false;
        return true;
I added the required statements.
RobertScheitlin__GISP
Chris,
  Sounds like a great time to start learning to use lang.hitch as this sounds like a scope issue.
on(dom.byId("btnFeedback"), "click", lang.hitch(this, function () {
    } else {
      return false;
    return true;
ChrisSergent
I added it and got the following error:
Uncaught TypeError: this.validate is not a function
I also included my require statements for dojo/_base/lang and the variable.
Chris,
   So the reason is that the scope of "this" is NOT the form. What is the id of your from?
ChrisSergent
It feedbackModal.
I changed the code to:
(dom.byId("feedbackModal").validate())
and just used feedbackModal with and without quotes and tried prefixing with a # sign. Still the same error message.
