Unable to draw a polyline on map
1360
01-10-2014 08:21 AM
ShaningYu
Honored Contributor
Borrowed someone script that could draw a polyline on map (defined here: var polyline) in Portand, WA.  I added var polyline2 with the values, but this line was not drawing.  I am new in JS GIS.  Please help if you can share your experience.  Thanks in advance.
<!DOCTYPE html>
<html>
    <head>
        <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
        <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9">
        <meta name="viewport" content="initial-scale=1, maximum-scale=1, user-scalable=no">
        <title>Build your first application</title>
<link rel="stylesheet" type="text/css" href="http://js.arcgis.com/3.8/js/esri/css/esri.css">
        <style type="text/css">
            html, body, #map {
                padding: 0;
                margin: 0;
                height: 100%;
        </style>
        <script src="http://js.arcgis.com/3.8/"></script>
        <script>
            var map;
            require(["esri/map", "dojo/ready", "dojo/on", "esri/geometry/Polyline", "esri/graphic", "esri/symbols/SimpleLineSymbol", "dojo/domReady!"], function(Map, ready, on, Polyline, Graphic, SimpleLineSymbol) {
        var map = new Map("map", {
          center: [-77.1, 38.9], //longitude, latitude
          zoom: 11,
          basemap: "streets",
          slider: true, //default
          sliderPosition: "top-left" //default
        ready(function (){
          on(map, "load", drawPath);
          function drawPath(){
         var polylineJson = { "paths":[[[-122.68,45.53], [-122.58,45.55], [-122.57,45.58],[-122.53,45.6]]], "spatialReference":{"wkid":4326}};
            var polylineJson2 = { "paths":[[[201394.01178484457,173661.08635829584],[201392.0117168416,173661.08690949593],[ 201388.01158083565, 173661.08801189612 ],[ 201386.01151283266, 173661.08856309619 ],[ 201384.0114448297, 173661.08911429628 ],[ 201382.0113768267, 173661.08966549637 ],[ 201380.01130882374, 173661.09021669647 ],[ 201378.01124082075, 173661.09076789653 ] ] ],"spatialReference":{"wkid":102100} };
            var polyline = new Polyline(polylineJson);
            var polylineSymbol = new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new dojo.Color([255,0,0]), 3);
            var g = new Graphic(polyline, polylineSymbol, null, null);
            map.graphics.add(g);
      var polyline2 = new Polyline(polylineJson2);
      var g2 = new Graphic(polyline2, polylineSymbol, null, null);
            map.graphics.add(g2);
        </script>
    </head>
    <body class="claro">
        <div id="map"></div>
    </body>
</html>
JonathanUihlein
@Ken
Thank you for your help. You are completely correct. shaningesri made another thread on the topic earlier:
http://forums.arcgis.com/threads/99906-Add-graphic-not-successufl
It's always been a coordinates issue but I have been unsuccessful in communicating that to shaningesri.
KenBuja
MVP Esteemed Contributor
Are you sure those are the correct coordinates for the line? If you change the first coordinate, you'll see the line off the coast of Africa.
var polylineJson2 = { "paths":[[[2013940.01178484457,1736610.08635829584],...
Also, can you get in the habit of putting your code within the CODE tags? It makes it much easier to read.
JonathanUihlein
@Ken
ShaningYu
Honored Contributor
Jon:  Thanks for your help.  The pro. got solved after using correct LAT/LON values.
