unable to applyEdits()
2707
7
08-08-2012 12:33 AM
JanJeske
Im using a feature Server and want to add Points to it
But if i applyEdits() all the time i get back 'error:400 Unable to complete operation'
My server is 10.1 the SDE is 9.3 is that an issue ? with 10.0 it worked fine
In ArcMap adding Points works fine, too
The User has permissions to the FeatureClass
I testet it also direct to the Rest service same issue:
the json post to the Server is like this:
 [{"geometry":{"x":434686.6102382373,"y":5792087.627864312,"spatialReference":{"wkid":25832}},"attributes":{"Art_ID":null,"Art":null,"Bemerkung":null,"Strasse":null,"Str_kurz":null,"Hsnr":null,"Hsnr_ID":null,"Pers_ID":null,"Mitarb_ID":null,"Status":null,"Datum_ein":null,"Datum_bearb":null}}]
Any suggestions?
AndyStewart1
Installed SP1 for Server 10.1 and it fixed this problem.
HuiChen
I have met the same problem and issued a ticket to ESRI. The answer is that 10.1 does not work with SDE 9.3. Not sure if they are going to fix this issue or not.
Hui
JanJeske
Thanks for the reply. It seems that i have to wait until the SDE Upgraded to 10.1 😞
JanJeske
Now I tested it with 10.1 and it works 🙂
AndyStewart1
Is the 10.1 server still not compatible with the 9.3 SDE? We have run into this problem and upgrading the database is not an easy option right now.
AndyStewart1
AdrianMarsden
Honored Contributor
I was getting stuck here to.  We can' upgrade the SDE due to legacy MapObject code.  BUT reading
http://forums.arcgis.com/threads/57375-Why-would-I-install-ArcSDE-with-10.1
I seems we no longer need the SDE software to create a "SDE" database, just the client software.  So in ArcCat 10.1 I created a new enterprise database for the few things I want to be able to be edited via the browser.  It all works well - now I just need to update my code (it currently rights the XY to a SQL table that is read as an event theme)
Cheers
ACM
JanJeske
Yeah SP1 fixed the incompatibility. But it seems that it is faster with 10.1.
