UI customization - Sizable panel for map and scroobar
1198
01-22-2014 09:46 AM
ShaningYu
Honored Contributor
I borrowed ESRI BAAJ template and created a map page.  But I got 2 problems:
1) The scrollbar of the Right Panel is missing.  The related code is below:
<div id="rightPane" dojotype="dijit.layout.ContentPane" region="right" overflow: auto;>
</div>
and
<div dojotype="dijit.TitlePane" title="Switch Basemap" open="false">
<div id="basemapGallery" style="overflow:auto;"></div>
</div>
How can the scrollbar be added?
2) The center panel is container for the map.  But it is not well-sizable (e.g. the height and width have maximum values).
<div id="map" dojotype="dijit.layout.ContentPane" region="center" style="overflow:hidden;">
</div>
How can this problem be solved.
Thanks in advance if you can hint me.
ShaningYu
Honored Contributor
Using ESRI template, Prob. 1was gone.
ShaningYu
Honored Contributor
Prob. 1) got solved by adding
        <style>
            #basemapGallery { overflow: auto; }
        </style>
or
        <style>
            #rightPane { overflow:auto; }
        </style>
ShaningYu
Honored Contributor
