TypeScript missing 'undefined' for view.container property
758
03-22-2023 04:59 AM
Christer
ArcGis version:
"@arcgis/core": "4.26.5",
According to your own post about using ArcGis with React, we should have a useEffect that unsets the views container, which seems like the way to go for freeing up the resources \ WebGL contexts created.
useEffect(() => {
    ... Map initialization
    return () => (view.container = null);
Using React with the ArcGIS API for JavaScript (esri.com)
But your Typescript definition says that view.container needs to be a HTMLDivElement
  export class DOMContainer {
     * The `id` or node representing the DOM element containing the view.
     * [Read more...](https://developers.arcgis.com/javascript/latest/api-reference/esri-views-DOMContainer.html#container)
    container: HTMLDivElement;
While you initializer allows more options:
  interface DOMContainerProperties {
    container?: HTMLDivElement | string;
The workaround is to do:
useEffect(() => {
    return () => (view.container = null as any);
But i believe the Typescript definition should be updated, if this is the preferred way to cleanup.
