typescript error creating MapView from TypeScript
1957
6
07-02-2025 06:14 PM
john_cartwright_noaa
Hello All,
Can someone tell me how to address the following TypeScript error:
 const view = new MapView({
        container: mapDiv.current,
        // ERROR: "Type 'WebMap' is not assignable to type 'MapProperties'."
        map: webmap
JSAPI version 4.33
Thanks!
ReneRubalcava
Esri Frequent Contributor
Found it! You have the old AMD types installed too, remove those and you should be good.
https://github.com/CI-CMG/pointstore-dashboard/blob/main/package.json#L21
Probably want to remove "src" from includes in the node tsconfig too
https://github.com/CI-CMG/pointstore-dashboard/blob/main/tsconfig.node.json#L27
JonathanDawe_BAS
Is your webmap constructed using `new Webmap`? I don't get a typescript error in my application using arcgis 4.33 with equivalent code.
Thanks for your reply. Yes, it looks like this:
const webmap = new WebMap({
  portalItem: {
  // Type 'WebMap' is not assignable to type 'MapProperties'.
  map: map
I wonder if I'm missing something in my VSCode configuration then?
ReneRubalcava
Tried this out with a new vite TS app and not seeing this. Could you try deleting your node_modules/package-lock.json/yarn.lock and try again? If you have a github repro, can take a look.
Thanks for the suggestion and your offer to help Rene. Re-creating the node_modules and package-lock.json file did not seem to help.
Here's the repo: [email protected]:CI-CMG/pointstore-dashboard.git
ReneRubalcava
Thank you Rene - that's really helpful!
