TypeError: Object #<Object> has no method 'disableDoubleClickZoom'.
978
06-20-2013 08:52 AM
YgorThomaz
Hello guys,
My mission as a newbie ArcGIS JS developer continues. I created this class:
// NavigationToolBar.js
define([
        "dojo/_base/declare",
        "dojo/_base/connect",
        "dijit/registry",
        "dijit/form/Button",
        "esri/toolbars/navigation",
        "dojo/domReady!"],
  function (declare, connect, registry, Button, Navigation) {
      return declare([], {
          declaredClass: "modules.NavigationToolBar",
          // lifecycle: 1
          constructor: function (map) {
              var navToolbar = new Navigation(map);
              var buttonZoomin = new Button({
                  iconClass: 'zoominIcon',
                  onClick: function () {
                      navToolbar.activate(esri.toolbars.Navigation.ZOOM_IN);
              }, "zoomin");
// main.js
require([
        "esri/map",
        "esri/dijit/BasemapGallery",
        "modules/MapConfig",
        "modules/NavigationToolBar",
        "dojo/domReady!"],
    function (
        connect,
        Map,
        BasemapGallery,
        MapConfig,
        NavigationToolBar
        // Crée et configure la Carte Interactive.
        var map = new Map("map", {
            basemap: "streets",
            logo: false,
            sliderStyle: "large",
            showAttribution: false
        var navigationToolBar = new NavigationToolBar({
            map: map
    <div id="topNavBar" data-dojo-type="dijit/Toolbar">
        <button id="zoomin" type="button">
        </button>
When I click on the ZOOM button I get the following error: Uncaught TypeError: Object # has no method <Object> 'disableDoubleClickZoom'. I think the problem is how I'm working with the object navToolbar.
Ty!
