Tutorial: Advanced web map printing/exporting using arcpy.mapping
4937
6
10-24-2014 02:53 AM
HabG_
Hi All,
I have followed the step-by-step instructions of the (
) tutorial in ArcGIS Resources and it all works well. I have tested the geoprocessing service in ArcMap using a GIS server connection to my ArcGIS for Server and it works well. I copied and pasted the ArcGIS API for JavaScript code to the sandbox and changed the URLs of the map service and geoprocessing service to my server and run it. The results show that everything displayed well, however when I clicked on the print button it doesn't print anything. I know the HTML version used in this example is HTML 4.01 and JavaScript API version is 3.0. Can anyone please help me fix the print problem and change the code to the current version of JavaScript API 11 (or 10) and HTML 5?
Thanks
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8"/>
    <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" />
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
    <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.0/js/dojo/dijit/themes/claro/claro.css">
    <script src="http://serverapi.arcgisonline.com/jsapi/arcgis/3.0/"></script>
    <script type="text/javascript" language="Javascript">
      dojo.require("esri.map");
      dojo.require("esri.tasks.PrintTask");
      dojo.require("dijit.form.Button");
      dojo.require("dijit.form.CheckBox");
      dojo.require("dijit.form.ComboBox");
      var layer, map, visible = [];
      var printTask, params;
      function init() {
        var startExtent = new esri.geometry.Extent({"xmin":-2260000,"ymin":-1500000,"xmax":2250000,"ymax":1220000,"spatialReference":{"wkid":102008}});
        map = new esri.Map("map", {extent:startExtent});
        var dynUrl = "http://myserver:6080/arcgis/rest/services/USA/ConterminousUSA/MapServer";
        layer = new esri.layers.ArcGISDynamicMapServiceLayer(dynUrl, { "id": "ConterminousUSA" });
        if (layer.loaded) {
          buildLayerList(layer);
        else {
          dojo.connect(layer, "onLoad", buildLayerList);
  var printUrl = "http://myserver:6080/arcgis/rest/services/USA/AdvancedHighQualityPrinting/GPServer/AdvancedHighQuali...";
  printTask = new esri.tasks.PrintTask(printUrl, {async: true});
  params = new esri.tasks.PrintParameters();
        params.map = map;
      function buildLayerList(layer) {
        var items = dojo.map(layer.layerInfos,function(info,index){
          if (info.defaultVisibility) {
            visible.push(info.id);
          return "<input type='checkbox' class='list_item' checked='" + (info.defaultVisibility ? "checked" : "") + "' id='" + info.id + "' onclick='updateLayerVisibility();' /><label for='" + info.id + "'>" + info.name + "</label>";
        dojo.byId("layer_list").innerHTML = items.join();
        layer.setVisibleLayers(visible);
        map.addLayer(layer);
      function updateLayerVisibility() {
        var inputs = dojo.query(".list_item"), input;
        visible = [];
        dojo.forEach(inputs,function(input){
          if (input.checked) {
              visible.push(input.id);
        //if there aren't any layers visible set the array to be -1
        if(visible.length === 0){
          visible.push(-1);
      function print(){
        var layout = dojo.byId("layout");
        var index = layout.selectedIndex;
  var selectedValue_layout = layout.options[index].value;
  var format = dojo.byId("format");
        var index = format.selectedIndex;
  var selectedValue_format = format.options[index].value;
  var georef_info = dojo.byId("georef_info");
        var index = georef_info.selectedIndex;
  var selectedValue_georef_info = georef_info.options[index].value;
  var legendLayer = new esri.tasks.LegendLayer();
  legendLayer.layerId = "ConterminousUSA";
  legendLayer.subLayerIds = [];
  if (CapitalCities.checked == true)
      legendLayer.subLayerIds.push(0);
  if (InterstateHighways.checked == true)
      legendLayer.subLayerIds.push(1);
      if (Rivers.checked == true)
      legendLayer.subLayerIds.push(2);
      if (Lakes.checked == true)
      legendLayer.subLayerIds.push(3);
      if (StateBoundaries.checked == true)
      legendLayer.subLayerIds.push(4);
        params.template = {layout: selectedValue_layout, format: selectedValue_format, layoutOptions: {legendLayers:[legendLayer]}};
        params.extraParameters = {Georef_info: selectedValue_georef_info};
        printTask.execute(params, printComplete);
      function printComplete(result){
        window.open(result.url);
      dojo.addOnLoad(init);
    </script>
  </head>
  <body class="claro">
    <div id="map" style="width:1000px; height:600px; border:1px solid #000;"></div>
    <br />
    Layout Template:
    <select id="layout" >
      <OPTION value="CentralUSA">CentralUSA</OPTION>
  <OPTION value="ConterminuousUSA">ConterminuousUSA</OPTION>
  <OPTION value="NortheasternUSA">NortheasternUSA</OPTION>
  <OPTION value="NorthwesternUSA">NorthwesternUSA</OPTION>
  <OPTION value="SouthernUSA">SouthernUSA</OPTION>
  <OPTION value="SouthwesternUSA">SouthwesternUSA</OPTION>
    </select>
      Format:
    <select id="format">
      <OPTION value="PDF">PDF</OPTION>
  <OPTION value="PNG">PNG</OPTION>
    </select>
      Include Georef info?
    <select id="georef_info">
      <OPTION value="True">True</OPTION>
  <OPTION value="False">False</OPTION>
    </select>
    <br /><br />
    Table of Contents: <br /><span id="layer_list"></span>
    <br /><br />
    Include in Legend: <br />
    <label><input type="checkbox" name="CapitalCities" checked="checked">Capital Cities</label>
  <label><input type="checkbox" name="InterstateHighways" checked="checked">Interstate Highways</label>
  <label><input type="checkbox" name="Rivers" checked="checked">Rivers</label>
  <label><input type="checkbox" name="Lakes" checked="checked">Lakes</label>
  <label><input type="checkbox" name="StateBoundaries" checked="checked">State Boundaries</label>
  <br /><br />
  <input type="button" id="print" value="Print" onclick="print();"/>
  </body>
</html>
RobertScheitlin__GISP
Hab
  you were close. Here is the code working:
<!DOCTYPE html>
<html>
<head>
  <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
  <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no" />
  <title>Simple Map</title>
  <link rel="stylesheet" href="http://js.arcgis.com/3.11/dijit/themes/claro/claro.css">
  <link rel="stylesheet" href="http://js.arcgis.com/3.11/esri/css/esri.css">
  <script src="http://js.arcgis.com/3.11/"></script>
  <script>
    require([
      "esri/map",
      "esri/tasks/PrintTask",
      "dojo/on",
      "dijit/form/Button",
      "dijit/form/CheckBox",
      "dijit/form/ComboBox",
      "dojo/domReady!"
      function (Map, PrintTask, on, Button, CheckBox, ComboBox) {
          "xmin": -2260000,
          "ymin": -1500000,
          "xmax": 2250000,
          "ymax": 1220000,
          "spatialReference": {
            "wkid": 102008
          extent: startExtent
        var dynUrl = "http://gislap183:6080/arcgis/rest/services/USA/ConterminousUSA/MapServer";
        layer.on('load', function(evt){
        var printUrl = "http://gislap183:6080/arcgis/rest/services/USA/AdvancedHighQualityPrinting/GPServer/AdvancedHighQual...";
          async: true
        params.map = map;
        on(dojo.byId("print"), "click", function () {
          myprint();
          var items = dojo.map(layer.layerInfos, function (info, index) {
          var inputs = dojo.query(".list_item"),input;
          visible = [];
          dojo.forEach(inputs, function (input) {
          if (visible.length === 0) {
            visible.push(-1);
        function myprint() {
          if (dojo.byId("CapitalCities").checked == true) {
          if (dojo.byId("InterstateHighways").checked == true) {
          if (dojo.byId("Rivers").checked == true) {
          if (dojo.byId("Lakes").checked == true) {
          if (dojo.byId("StateBoundaries").checked == true) {
          params.template = {
            layoutOptions: {
              legendLayers: [legendLayer]
        function printComplete(result) {
  </script>
</head>
  <br />Layout Template:
  <select id="layout">
  </select>
  Format:
  </select>
  </select>
  <br />
  <br />Table of Contents:
  <br />
  <br />Include in Legend:
  <br />
  <label>
    <input type="checkbox" id="CapitalCities" checked="checked">Capital Cities</label>
  <label>
    <input type="checkbox" id="InterstateHighways" checked="checked">Interstate Highways</label>
  <label>
    <input type="checkbox" id="Rivers" checked="checked">Rivers</label>
  <label>
    <input type="checkbox" id="Lakes" checked="checked">Lakes</label>
  <label>
    <input type="checkbox" id="StateBoundaries" checked="checked">State Boundaries</label>
  <br />
  <br />
  <input type="button" id="print" value="Print" />
</body>
</html>
HabG_
I have changed the codes similar to the one below (please note I have changed the name of my server to "myserver") and it printed a PDF like the image below, but I want to print only the image area not the text information.
<!DOCTYPE html>
<html>
  <head>
    <script>
  require(["esri/map", "esri/tasks/PrintTask", "dijit/form/Button", "dijit/form/CheckBox", "dijit/form/ComboBox"],
    function(Map, PrintTask, Button, CheckBox, ComboBox) {
      function init() {
        if (layer.loaded) {
        else {
        params.map = map;
        visible = [];
          visible.push(-1);
      function print(){
    </script>
  </head>
    <br />
    Layout Template:
    </select>
      Format:
    </select>
    </select>
    <br /><br />
    <br /><br />
  <br /><br />
  </body>
</html>
Hab
<!DOCTYPE html>
<html>
<head>
  <script>
    require([
      "esri/map",
      "dojo/on",
      "dojo/domReady!"
          "xmin": -2260000,
          "ymin": -1500000,
          "xmax": 2250000,
          "ymax": 1220000,
            "wkid": 102008
          extent: startExtent
          async: true
        params.map = map;
          myprint();
          visible = [];
            visible.push(-1);
          params.template = {
            layoutOptions: {
  </script>
</head>
  </select>
  Format:
  </select>
  </select>
  <br />
  <br />
  <br />
  <label>
  <label>
  <label>
  <label>
  <label>
  <br />
  <br />
</body>
</html>
HabG_
Thanks Robert, this works perfect.
JenniferStone
Rob (if I may),
Will this work in ArcGIS 9.3? Which version of py? I have been tasked with writing/finding a script that will allow us to use our current tax map plotting routine, all VBA based, in ArcGIS 10 when we upgrade. Problem is, I don't have any experience writing python scripts although I have watched the tutorials and webinars offered by esri. If I know this can work in 9.3 then I can figure out what I need to do to make it work, usually, hopefully...
Jenn
Jennifer,
     arcpy.mapping that is used in this was not introduced until ArcGIS 10. So the simple answer is no.
ShruthiSrinivasan1
Robert,
Do you get the legend printed correctly for sub layer 4 (USA Boundary)? I wanted to test if the layer headings for USA Boundary was displaying, but it doesn't show up on the legend. Below is the JSON and attached are the screenshots.
print1.jpg:
{"operationalLayers":[{"url":"http://test/arcgis/rest/services/USA/ConterminousUSA/MapServer","title":"MyDynamicService","opacity":1,"id":"MyDynamicService","visibility":true,"visibleLayers":[0,2,3,4,5,6,7]}],"mapOptions":{"extent":{"xmin":-2200000,"ymin":500000,"xmax":-1300000,"ymax":1300000,"spatialReference":{"wkid":102008}},"scale":5000000,"rotation":0},"layoutOptions":{"copyrightText":"","authorText":"","legendOptions":{"operationalLayers":[{"id":"MyDynamicService","subLayerIds":[0,2,5]}]}}}
print2.jpg:
{"operationalLayers":[{"url":"http://test/arcgis/rest/services/USA/ConterminousUSA/MapServer","title":"MyDynamicService","opacity":1,"id":"MyDynamicService","visibility":true,"visibleLayers":[0,2,3,4,5,6,7]}],"mapOptions":{"extent":{"xmin":-2200000,"ymin":500000,"xmax":-1300000,"ymax":1300000,"spatialReference":{"wkid":102008}},"scale":5000000,"rotation":0},"layoutOptions":{"copyrightText":"","authorText":"","legendOptions":{"operationalLayers":[{"id":"MyDynamicService","subLayerIds":[0,2,4]}]}}}
Thanks.
