Trying to Use Custom Address Locator in ArcGIS Online Application
6926
13
08-12-2014 07:30 AM
ChrisSergent
Here is the code that we have with our address locator. What do we need to do to get it to work?
<!DOCTYPE html>
<html>
<head>
<title></title>   <!-- Define the versions of IE that will be used to render the page. See Microsoft documentation for details. Optional. -->
<meta http-equiv="X-UA-Compatible" content="IE=edge">
<meta charset="utf-8">
<!-- Responsive -->
  <meta name="viewport" content="width=device-width, initial-scale=1, maximum-scale=1, user-scalable=no">
<meta name="mobile-web-app-capable" content="yes">
<meta name="apple-mobile-web-app-capable" content="yes">
<meta name="apple-mobile-web-app-status-bar-style" content="default">
<!-- End Responsive -->
<!-- Use protocol relative urls that way if the browser is viewing the page via HTTPS the js/css file will be requested using the HTTPS protocol -->
<link rel="stylesheet" href="https://community.esri.com//js.arcgis.com/3.10/js/esri/css/calcite/calcite.css">
<link rel="stylesheet" href="https://community.esri.com//js.arcgis.com/3.10/js/esri/css/esri.css">
<!-- Load any application specific styles -->
<link rel="stylesheet" href="css/styles.css">
<!--[if IE 8]>
<link rel="stylesheet" href="css/ie.css">
<![endif]-->
</head>
<body class="calcite app-loading no-touch">
<!-- Loading Indicator -->
<div class="loading-indicator">
<div class="loading-message" id="loading_message"></div>
</div>
<!-- Map -->
<!-- The ArcGIS API for JavaScript provides bidirectional support. When viewing the application in an right to left (rtl) language like Hebrew and Arabic the map needs to remain in left-to-right (ltr) mode. Specify this by setting the dir attribute on the div to ltr. -->
<div id="mapDiv" dir="ltr"></div>
<!-- Panel Content -->
<div id="panelContent">
<div id="panelPages"></div>
</div>
<!-- Panel Top -->
<div id="panelTop" class="bg rounded shadow">
<!-- Panel Title -->
<div id="panelTitle">
<div class="fc" id="panelText">
</div>
<div id="panelSearch">
<div id="panelGeocoder"></div>
</div>
<div id="panelMenu" class="icon-menu icon-color"></div>
</div>
<!-- Panel Tools -->
<div id="panelTools">
<!--Tools are created programatically-->
</div>
</div>
<script type="text/javascript">
var package_path = window.location.pathname.substring(0, window.location.pathname.lastIndexOf('/'));
var dojoConfig = {
// The locationPath logic below may look confusing but all its doing is
// enabling us to load the api from a CDN and load local modules from the correct location.
packages : [{
</script>
<script type="text/javascript" src="//js.arcgis.com/3.10/"></script>
require(["application/template", "application/main"], function(Template, Main) {
// create the template. This will take care of all the logic required for template applications
var myTemplate = new Template();
var myApp = new Main();
myTemplate.startup().then(function(config) {
myApp.startup(config);
}, function(error) {
// something went wrong. Let's report it.
myApp.reportError(error);
</script>
var map;
var locatorUrl = "http://maps.decaturil.gov/arcgis/rest/services/Public/WebAddressLocator/GeocodeServer";
var myGeocoders = [{
url: locatorUrl,
singleLineFieldName: "SingleLine",
geocoder = new Geocoder({
map: map,
autoComplete: true,
arcgisGeocoder: false,
geocoders: myGeocoders
},"search");
geocoder.startup();
</script>
</body>
  </html>
Tags (1)
KellyHutchins
Esri Notable Contributor
If you aren't using the Esri world geocoder and your custom locator then auto complete won't be enabled. To enable it edit the main.js file and at approximately line 301 you'll see code like this:
            var options = {
                map: this.map,
                autoNavigate: false,
                theme: "simpleGeocoder",
                autoComplete:hasEsri
Modify the line with autoComplete: hasEsri to be autoComplete: true
ChrisSergent
That line wasn’t in the main.js file but I performed a search and changed it in the file named CreateGeocoder.js and the autoComplete is still not working.
I uploaded the project to dropbox at this location if that helps: https://dl.dropboxusercontent.com/u/30750655/ago_atlas.zip
KellyHutchins
Just unzipped your app and tested locally and the auto complete displayed for me. Screen Shot 2014-08-14 at 9.18.38 AM.png
ChrisSergent
Rookie mistake.  I didn't clear my cache. It's working now. Thanks for the help.
